Gorilla spring
Old Sep 15, 2011 | 02:36 PM
zangx1's Avatar
zangx1
Default Gorilla spring
HELP!!!
How do you safely install this
spring?
Old Sep 15, 2011 | 02:54 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
do a search for Plasticman and/or gorilla spring and you will find info.
Bill
Old Sep 15, 2011 | 04:28 PM
Plasticman's Avatar
Plasticman
Here is the info that I had previously wrote (about installing the C1 return spring).
No special tool is required other than a large Crescent Wrench (12" or so). Assemble the spring at the bottom, then assemble it onto upper bracket (the bracket that bolts to the cross shaft), then assemble the bracket to the cross shaft using the bottom bolt only (leave this bolt loose so that the bracket can pivot in relation to the cross shaft). Then attach the Crescent wrench to the top of the bracket (across the upper end of the bracket - about a 1" gap at the Crescent wrench) and pivot the bracket into place and insert the top bolt. Adjust the bracket via the Crescent wrench (in relation to the cross shaft) so that the specified effort is obtained at the pedal, and then tighten the 2 bolts (see the ST-12 for adjustment procedure - you do have the ST-12 don't you?).
Hope this helps,
Plasticman
Old Sep 15, 2011 | 04:41 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Hope this helps,
Plasticman
Here is my lovely artwork on where the wrench goes !
Old Sep 15, 2011 | 06:45 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Old Sep 15, 2011 | 08:01 PM
1snake's Avatar
1snake
Do like Plasticman said. It is described in the ST-12. People have been cussin' at installing the gorilla spring for years but if they follow the instructions written by Chevrolet over 50 years ago, it takes less than 1 minute to install it. I've seen people make special tools, pullers etc. or wedge washers in it to expand it enough to get it hooked up and I laugh my azz off. If they only knew how to read the service manual.
Jim
Old Sep 16, 2011 | 09:47 AM
Steve59's Avatar
Steve59
Just watch your knuckles.....
Old Mar 14, 2012 | 10:05 PM
dcrocker316's Avatar
dcrocker316
thanks plasticman. Dave
Old Aug 25, 2017 | 05:39 PM
1961Corvette's Avatar
1961Corvette
7th Gear
Hi,
we've had our 61 in the family since 1963, and trying to install the gorilla spring, and appears to be a couple inches too short, is this right? Should it have to be extended thta much to connect to the linkage from the frame?
Old Aug 25, 2017 | 06:15 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Originally Posted by 1961Corvette
Hi,
It's not too short if it's factory type spring. In Franks picture, the bracket pivots down on the lower bolt, then attach the spring, then use the crescent wrench to bring it up to the top and line up the bolt hole for the top bolt and tighten everything down.
Old Aug 25, 2017 | 06:31 PM
Frankie the Fink
Army
Make SURE you have the hook at the top and the hairpin clip at the bottom of the spring per the picture - I've actually seen the Bubba'ed in that regard. Rocking the Z-bar as indicated you will come to a 'sweet spot' where the spring almost falls on - then you'll ask yourself what the big deal was...
Old Aug 25, 2017 | 06:43 PM
65GGvert's Avatar
65GGvert
I used a 3 ft long floor jack handle to do it by myself. I put the handle behind the part of the bar where the spring adaptor plate oval thing goes and under a frame attachment and pushed down the "z" bar and hooked the plate on and released the handle, took about 5 seconds. As Frankie said, once you get over the center, the farther you go, the less tension there is on the spring and it gets easier.
Old Aug 25, 2017 | 07:06 PM
MOXIE62's Avatar
MOXIE62
I've got an old Model A jack that the top will fit right between the 531367 clip and the black arm with the red lines drawn on it. I just jack it up till I could get the top bolt in. Worked well for me. You need to make sure that horse show clip is snug on the frame. Had one to pop off in traffic and never could find it. Don't know why the did not weld that in place.
Old Aug 25, 2017 | 09:07 PM
1961Corvette
7th Gear
Success, I've had it installed wrong for 35 years since i did a frame off restauratuon..
Old Aug 25, 2017 | 09:49 PM
Geralds57's Avatar
Geralds57
Old Aug 26, 2017 | 09:17 AM
1961Corvette
7th Gear
need to weld up the groove though, as original lever on vehicle and about 7/8 wore through...nice to have a MIG handy
To Gorilla spring
