Just Bad Points?
Hi Mike,
I agree you should run whatever is "right" for you and your car. It's nice to have options though. In 40 years I have had my car quit a number of times: Twice on the grid and once in Washington's Crossing state park at midnight (don't ask
) due to broken FI drive cable. I was able to continue because I had a spare in my glove compartment. SO, the key, as you mention, is having the knowledge and experience to troubleshoot and repair your problem. That said, if electronic ignitions were less reliable than points, then NEW cars would come with points
My car was only towed once in 2007 when an oil canister gasket blew...
I spent a very uncomfortable couple of hours in front of a bowling alley in a bad neighborhood one night when a buddy's Volkswagen beetle died because one side of his points cracked in half.
Admittedly never saw that before or since.
Bill
i got to the point where i used to carry a spare distributor, now i just carry a spare circuit board.
I don't see anything wrong with the ignitions that come on new cars today. You can buy parts for them anywhere and they are reliable enough, they seldom need attention.
My comments were directed at these aftermarket gizmos that you have to buy mail order. Assuming you do have a problem with them when you're on the road, hitchhike into your nearest Auto Zone and after the clerk fires up his keyboard and asks you all the dumb questions about 4,6 or 8 cylinder, then tell him what you really need is a Pertronix something or other. Never mind his "deer in the headlight" or "cow having a calf" look!
When I leave home in one of my old cars, I don't take tools, I don't take spare parts and I don't live in the middle of a large metropolitan area. I live in the country and if you break down, you'll either fix it on the spot or call for help.
All I said was, standard points limits my rpm to a safe level for about $15/set. Pertronix is how much? $100-$150? One set of points will last me 10-12 years. I think the set of points in one car has been in there 4-5 years and I've never touched them. Another car, I put the points in in 1973 and I adjusted the dwell on them last year. I have another old car around here I bought in 1980 and I don't recall ever touching the points.
Therefore, when I read some of these posts about "help, my car won't run", "how do I convert to Pertronix and get rid of these PIA points", "emergency tool/parts kits" and other such stuff, I just find it somewhat amusing to read those posts.
PS. I have several sets of Echlin and Delco heavy duty points laying in the cabinet that will let my engines run to 7000 rpm without misfire. These are the heavy duty Z-28 points. They're staying in the cabinet as the cost to run my engine to 6000 has been nothing. The cost to continually run it around 7000 could be considerable. I passed through that 7000 rpm stage in my life about 50 years ago.
On second thought, a loose/worn breaker plate can also cause that. I never had it happen to me but used to hear of it.
Delco D103P & D203 condenser
NAPA CS777A & RR174 condenser
Niehoff DR3HV & DR22 condenser
BWD A72 & G102A condenser
Standard DR-2236P & DR-60 condenser
That's the best place for him to be. Have had him there for a couple of months now and am amazed at how much more enjoyable it makes the Forum. Decided I liked it so much I even signed up as a paying member, so now I can say I put my money where my mouth (keyboard?) is!
Points were not loose - either time. I'll check the bearing point. Not sure how to check for worn/ loose breaker plate, but if everything else checks out and problem still not solved i'll ask you about that.
