Speaker Grill Screen
Old 12-07-2011, 05:42 PM
bmcnitt
bmcnitt's Avatar
Default Speaker Grill Screen
I was wondering if there is a way to take this off from the top or is it secured from the bottom? Dont really understand how it is mounted and I need to get it off but can't really see anything from either side that helps.
Thanks - Brian
Old 12-07-2011, 05:53 PM
65-396's Avatar
the metal screen is held in by nuts on all 4 corners. They also hold the speaker in place. You can access them after removing the glove box liner.
Old 12-08-2011, 05:41 PM
bmcnitt
bmcnitt's Avatar
That helps, thanks for the reply.
Old 12-08-2011, 06:34 PM
Bill Lacy
Bill Lacy's Avatar
I have found that it helps if you remove the clock. You will be able to look through the clock hole and see better.
Bill
Old 12-08-2011, 07:43 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
And have bandaids handy, to stop the bleeding. Everything up there seems to be sharp.
Old 12-08-2011, 08:22 PM
cookie_monster
cookie_monster's Avatar
I replaced mine about a year ago. Based on what I read hear on the forum, I was expecting it to be a bear - wasn't bad at all (no AC).
Remove glove box (10-15 minutes), remove clock (2-3 min), 3 of the 4 nuts on the grille are easy to reach and remove, the 4th nut (driver side closer to windshield) takes a little more fitness. 1/4" drive ratchet, magnetic (magnet inserts) socket and 12" extension, and you on your back will do it.
Plan on doing a lot of dusting/cleaning after you remove the glove box...you'll see what I mean.
Good luck!
Old 12-08-2011, 11:22 PM
jbutler
jbutler's Avatar
I can send you a photo of the underside, I have the dash out right now with the speaker and defroster vent bolted up. That will show you the bolt pattern.
64 w/AC
Let me know
Jim
Old 12-09-2011, 08:06 AM
TheSaint
TheSaint's Avatar
I just put my hands up there and loosened the 4 small nuts.No problem but you have to take off the radio side panel
To Speaker Grill Screen
Quick Reply: Speaker Grill Screen
