speaker grate question
Old Dec 16, 2011 | 08:00 PM
stall's Avatar
stall
Default speaker grate question
On my 64 can i replace the radio speaker from the top by removing the grate (cover?). Does the grate just snap in?
Thanks Guys
Old Dec 16, 2011 | 08:12 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Bolted from the underside....the grill bolts are the speaker bolts also....
Old Dec 16, 2011 | 08:18 PM
DansYellow66's Avatar
DansYellow66
Yep - not fun but do-able.
Old Dec 16, 2011 | 08:23 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Remove the entire glove box assembly. Dennis
Old Dec 16, 2011 | 10:17 PM
nassau66427's Avatar
nassau66427
From: going faster miles an hour...with the radio on in browns mills new jersey
Nope - not unless someone has cut out part of the dash.
Still have to unbolt it from underneath.
Old Dec 16, 2011 | 11:18 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
If you pull the 2 panels on either side of the console, you can reach up with a nut driver and remove the nuts. Be patient and you'll get there, at first it seems impossible.
Old Dec 17, 2011 | 07:05 AM
Jeff Garner's Avatar
Jeff Garner
With patience you can get it. A light helps too.
I have a problem with my speaker grill sticking up in the front. Don't know how to pull it down flush with the console/dash without bending it. The screws are tight and the hold down clips are in place. How do you guys get it to fit flush?
Old Dec 17, 2011 | 08:08 AM
DansYellow66
Aren't they all like that? It seems like everyone I've seen has been. I studied mine years ago when I had it out aand deccided trying to do something about it wasn't worth the effort.
Old Dec 17, 2011 | 08:32 AM
nassau66427
If you lay the speaker grill on the dash without a speaker installed you'll see that it lays in there pretty flush.
The problem is that the two studs in the dash that mount the forward side of the speaker are a little too far to the rear of the car.
If you moved them forward a tad, the speaker grill would fit better.
The downside to that is that your car would no longer appear to be original.
Old Dec 17, 2011 | 03:26 PM
JohnZ's Avatar
JohnZ
That's the nature of the beast - we even acknowledge it in the judging guide ("fit is generally poor"). Some fit better than others - not much you can do about it.
To speaker grate question
