>>>>>Does anybody know where this brown wire hanging under my dash goes?<<<<<
Ok, here is a close-up pic of the switch. It looks like I have the connecter on it but it doesn't fit the connecter on the wire (see wire pic above). I tried to reconnect it but it just isn't the same size or anything. Could there still be a missing piece to one of the connecters?
BTW, it looks like I seriously need to pull all of that stuff out, repaint it and possibly install a new switch. I looks like it could be, ohhh...I dunno...46 years old or something!
As the poster above notes, please confirm that the ignition switch was on when you tried to ground to test the warning light?
The wiring diagram shows a few different tan wires in the dash area, but the evidence is still got me thinking its the PB switch...
On the switch condition, mine looked to be in similar condition but it seemed to work flawlessly when I cleaned it up with some contact cleaner...simple design and pretty resilient in all metal construction.
Nice avatar by the way!
My best reminder of when the PB is left on is when the T handle of it gouges me in my right shin or clips my right knee cap!
No wonder they moved it to the center console for '67.
BTW, I had to look hard to find a replacement PB bracket (mine was missing when I bought the car). The T handle, shaft, ratchet pawl and pin are readily avaialbe, but try finding the black bracket part itself that bolts to the dash and screws into the firewall...that's how I ended up with a '66 with the empty 4-way hole in it. Swap meet or e-bay were my only sources there.
I imagine the guy took it off because he got tired of it hitting his leg if he was a tall guy too...
I'm on my way back out to work on this thing, clean the switch up and get more pictures of the wire connecter since I removed the covering on it.
BTW, I did NOT have the ignition turned on when I tested the ground on that wire. I've been drugged up from a kidney stone the last couple of days so stupid things are bound to follow. I'll retest it correctly this time.
Ok, problem SOLVED!!! I grounded the wire and it turned on the PB light.
So, I resized the connecter on the switch to take the connecter on the wire and VIOLA!
I now have a PB warning light.
Thanks for all the help guys, you rock!
Yeah, I'm still buzzed on the pain meds I took for the kidney stone I finally passed this morning, upside down in the floorboard I figured, hell...that's good enough for me.
Besides, I'll be taking all of that apart again this summer to clean and repaint everything. It looks like crap under there!
Thanks again for the info guys!
