Rear Spring Arch Dimensions??
Old Jan 18, 2012 | 09:32 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Default Rear Spring Arch Dimensions??
I'd like to get my original spring re-arched. I have a truck spring shop that does that type of work but would like to know if there are certain dimensions of the amount of arch that I should request. I don't want the rear sitting too high after it's done. Thanks for any help. Dave
Old Jan 18, 2012 | 11:13 AM
Ron Miller's Avatar
Ron Miller
Yep, there are dimensions available. Someone had them posted in a previous forum post which I don't have immediately available. I'll look a bit later, maybe before I get to it someone else will respond!
Old Jan 18, 2012 | 11:44 AM
vark_wso's Avatar
vark_wso
The typical inspection go/no-go dim that has been used is 10" +/- 1/8 measured from the centers of the end bolt holes to the bottom of the lower leaf arch. Not real easy to determine as the holes become elliptical & the lower edge has the center bolt in the way. (Assuming 9-leaf OEM spring to start with)
'Cold' re-arching is another matter ...
Old Jan 18, 2012 | 11:53 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Maybe if you include what kind of car you are working on somebody can help you...
I have the dimensions for a C1 rear spring set...
Old Jan 18, 2012 | 04:29 PM
dkleather's Avatar
dkleather
The car is a 64 Corvette convertible...stock suspension.
Old Jan 18, 2012 | 04:31 PM
Frankie the Fink
Army
Can't help then....C1 leaf springs should have a 5-1/2" to 5-3/4" free arch when measured as shown in the picture posted earlier...
Old Jan 18, 2012 | 04:34 PM
dkleather's Avatar
dkleather
[QUOTE=vark_wso;1579768538]The typical inspection go/no-go dim that has been used is 10" +/- 1/8 measured from the centers of the end bolt holes to the bottom of the lower leaf arch. Not real easy to determine as the holes become elliptical & the lower edge has the center bolt in the way. (Assuming 9-leaf OEM spring to start with)
Thanks Vark_wso for the info. It is an original 9-leaf spring and your picture was a great help as well. Thanks for posting. Dave
To Rear Spring Arch Dimensions??
