1964 steering dampner
Old Mar 22, 2012 | 05:07 PM
morningstar's Avatar
morningstar
2nd Gear
Default 1964 steering dampner
I have a 1964 vette (coupe) with no power steering or power brakes.
The original car had a 327/250 hp motor. I am replacing it with a 327/ 365 motor (deeper oil pan) it appears the deeper pan will interfere with the steering dampner. How is this resolved? I don not want to remove the dampner or use a shallow pan. What was the set up of the original 327/365 hp motors.
Please help Thanks Steve
Old Mar 22, 2012 | 05:17 PM
JohnZ's Avatar
JohnZ
Just remove the steering damper - 365's came without them.
Old Mar 22, 2012 | 05:32 PM
cam30era's Avatar
cam30era
I agree with JohnZ. My '65 L76 does not have a steering damper.
Old Mar 22, 2012 | 06:03 PM
RoadKing96's Avatar
RoadKing96
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
There is no steering dampener on the 365hp. The bigger oil pan GM used on them did NOT allow the room for one.
RK
Old Mar 23, 2012 | 01:50 PM
Mrbill_3's Avatar
Mrbill_3
Default steering damper
Is no the front end loose when driving with out the damper. I know that my 64 coupe did not have a damper installed when I bough her, She floated all over the road, then installed the sreering damper, made a difference driving.
Old Mar 23, 2012 | 02:00 PM
morningstar
2nd Gear
Thats what I am concerned about. Is there a way to keep the dampner? Perhaps extend it down an inch or two??
Old Mar 23, 2012 | 02:03 PM
cam30era's Avatar
cam30era
There is no looseness, nor instability in my '65 L76. Steering and handling are great, especially for a 47 year old car.
Old Mar 23, 2012 | 03:08 PM
LB66383's Avatar
LB66383
My '66 had no damper on it when I got it (and no power steering). When I rebuilt the suspension, I put a damper on it, and noticed no difference in the steering/performance.
Old Mar 23, 2012 | 09:44 PM
JohnZ's Avatar
JohnZ
There is nothing to be concerned about - 40% of production was big-blocks, and NONE of them had a steering damper. If it was that important, they wouldn't have built all the 365 and 375hp cars without them; they cancelled it completely for '68 and never used it again, with exactly the same chassis.
Old Mar 24, 2012 | 03:34 PM
Mrbill_3's Avatar
Mrbill_3
Default Steering dmper
What I did on my 64 coupe. was fabricate a longer bracket for the drag link and put spacers between the frame and the bracket.
Old Mar 24, 2012 | 03:45 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
I had the same situation with my 63. I added the dampner during my restoration.Mine never had one.
I didn't drive it much before the resto. So I can't attest to it's effectiveness.
But after much insistance in the past from JohnZ, that it's a needless item. I will go with that.
To 1964 steering dampner
