Embarrassing question
Old Mar 24, 2012 | 02:14 AM
Downdraft's Avatar
Downdraft
Default Embarrassing question
When I repainted the engine bay I also replaced the battery holder, the old one was correoded. It is a 327 car with the tray on the passenger side. Is the negative or positive on the engine side? Thanks. Alex
Old Mar 24, 2012 | 02:22 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Usually any car I work on the cables are only long enough and formed from years in a way as to make it pretty easy to tell. But the guys will let you know the "correct" way.
To me "correct" means it works great!
Old Mar 24, 2012 | 06:27 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
The positive goes on the engine side, the negative to the fender side.
BUT.................
There are 2 battery configurations. For the "correct" Corvette configuration, both posts are closest to the firewall.
Chuck
Old Mar 24, 2012 | 12:21 PM
Downdraft's Avatar
Downdraft
Thank you. Today I trucked the Vette from the body shop to the mechanic - next week we drop the Engine in........can't wait!
Old Mar 24, 2012 | 01:11 PM
toddalin's Avatar
toddalin
It is "safer" to put the positive toward the fenderwell and negative next to the engine. Then the fender and expansion tank protect the positive from shorting out should you drop something in the engine bay.
It is pretty easy to bridge the terminal next to the engine to something metal when you reach in with a big azzed screwdriver or wrench. It's better that this terminal be negative and not short out when you do.
It is also far easier to reach the cut-off switch (that mounts on the negativer terminal) in this position.
To Embarrassing question
