Pertronix Ignition help
Old Mar 25, 2012 | 01:38 PM
1955 copper's Avatar
1955 copper
2015 C1 of Year
Default Pertronix Ignition help
Those that have installed this after market part I need to know the part number used in a stock original V8 1955 265 engine Distributor. The person at the company (pertronix) dont seem to know thanks
Old Mar 25, 2012 | 02:08 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Unless your '55 distributor is different from my '64 distributor, the p/n I purchased, Pertronix Igintor II, 91181, should work.
Dave
Old Mar 25, 2012 | 02:40 PM
GEM '62's Avatar
GEM '62
Description of PERTRONIX 91181
Fits
1957-1959 and 1963-1974 AMC V8 with standard ignition
1957-1974 Buick V8 with standard ignition
1964-1974 Checker V8
1958-1974 Chevy V8 single or dual points
1956-1974 Cadillac V8 with standard ignition
1966-1974 Jeep 304 401 engine
1956-1974 Oldsmobile V8 with standard ignition
1957-1974 Pontiac V8 with standard ignition
1965-1966 Studebaker V8 with Delco distributor
1960-1961 Studebaker Lark and Regal with Delco distributor
1955-1956 Chevy Pertronix Ignitor Electronic Ignition Conversion Kit, V8
12383
55-56 Ign. conv., Pertronix, Ignitor Electronic (V8); kit
$91.95 KT
Add To Cart
Details
Old Mar 25, 2012 | 03:41 PM
1955 copper
2015 C1 of Year
Old Mar 25, 2012 | 07:35 PM
Pierre's Avatar
Pierre
If the same as the '56 265 225HP dual points distributor (1110879), you need Pertronix #91182D set up.
Pierre
Old Mar 25, 2012 | 09:32 PM
65tripleblack's Avatar
65tripleblack
If you have no intention of eliminating the ballast resistor and using a more powerful 45kv coil, then I recommend the M & H "Breakerless SE" over the Pertronix unit. Yes, the "SE" doesn't have the power wire from the pos coil terminal, but that's less important than the fact that the "SE" has a more robust, trouble free design.
I originally had a "SE" unit installed, and REALLY like its design. Unfortunately, it shouldn't be run with upgraded ignition components, so I had to reluctantly replace it with a Pertronix Ignitor II as the trigger for my 45 kv coil, MSD 6AL ignition module and fat 8.5 mm wires which are necessary since I now gap my plugs at 0.050".
To Pertronix Ignition help
