Started putting things together
Old Mar 31, 2012 | 09:40 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Default Started putting things together
and realized I still have to paint my steering column. Anyone know where I can get Daytona Blue 916 which is GM Code WA3112 , Ditzler PPG 12696 , Dupont 4395L, 181-96220 or Acme Rogers 9177, in a spray can?
Checked Paragon, Ecklers, Willcox, Long Island Corvette, Corvette Central.
none have it
Old Mar 31, 2012 | 10:27 PM
erb64's Avatar
erb64
I thought the column was black?
Old Mar 31, 2012 | 10:57 PM
TC233's Avatar
TC233
CF Senior Fox Bat
so did I, mine is blue though. Should it be black? Since you mentioned it, I googled "63 Corvette Interiors" under images. Red 63 are seen in pictures with Red columns or Black ones. Teal Blue with Black or Teal Blue?
Old Mar 31, 2012 | 11:03 PM
hzz's Avatar
hzz
Nope..should be blue if your interior is blue
63 steering columns were interior color
And the steering wheel itself was also interior color
64-67 were satin black
Old Mar 31, 2012 | 11:13 PM
TC233's Avatar
TC233
CF Senior Fox Bat
So I guess that begs the question where are people getting their matching spray paint, or do they do it when they paint the car?
Old Mar 31, 2012 | 11:19 PM
henry63's Avatar
henry63
Would the column be metallic like the exterior daytona blue?
Old Mar 31, 2012 | 11:20 PM
hzz's Avatar
hzz
I got the interior dye in the correct color that Corvette America makes.
Lots of vendors sell it
It may not be correct to "dye" metal, but it worked for me.
I used it to change color of dash pads from black to blue, and on the center of the console where the radio is.
Cleaned areas up well with lacquer thinner and sprayed multiple fine coats.
Should work on the steering column as well.
Old Mar 31, 2012 | 11:23 PM
hzz's Avatar
hzz
In your pictures the last red one is not a 63..its a 67
Wrong gauges....parking brake handle...and column and steering wheels should be red if it were a 63
If I keep helping you out can I grow to 5' even?
Old Apr 1, 2012 | 03:44 AM
GeoffM's Avatar
GeoffM
Not sure where to get it in the US but here in OZ the local Autopaint store mixes the paint for you and can put it in an aerosol can ready to go.
Old Apr 1, 2012 | 08:39 AM
napa68's Avatar
napa68
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
Try these guys.................
http://www.apstowerpaint.com/
Tim
Old Apr 5, 2012 | 03:07 PM
CorvetteCentral.com's Avatar
CorvetteCentral.com
Platinum Supporting Vendor
This is what we recommend.
Old Apr 5, 2012 | 05:11 PM
mrg's Avatar
mrg
I used the CA dark blue dye to redo the shifter console, lower inner windshield trim piece, and rear soft top frame guards. I thought it sprayed out well for a rattle can paint.
To my eye the color hue of the CA dark blue was a bit on the dark side.
Old Apr 15, 2012 | 08:34 AM
TC233's Avatar
TC233
CF Senior Fox Bat
Thanks, I have ordered the dye. Thanks for the help
Old Apr 15, 2012 | 09:52 AM
hzz's Avatar
hzz
How did you get them to ship it to Canada?
They usually won't do that.
Old Apr 15, 2012 | 01:17 PM
Rokndad's Avatar
Rokndad
Dennis, the Corvette America rattle can for 63 Dark Blue is spot on for our cars. The mast jacket, window trim, radio side panels and the kick panel metal all came out looking new. Smooth flowing paint. Don't forget the primer first for sanding. TR
Old Apr 16, 2012 | 03:31 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Thanks ordered it yesterday
Old Apr 16, 2012 | 03:32 PM
TC233's Avatar
TC233
CF Senior Fox Bat
I have a Drop box in Alexandria Bay New York
Old Apr 16, 2012 | 05:04 PM
TC233's Avatar
TC233
CF Senior Fox Bat
speaking of hoods, anyone need a 67 stinger that definetly needs to be repainted
http://www.ebay.com/itm/Original-196...sories&vxp=mtr
To Started putting things together
