Shift boot
Old Apr 5, 2012 | 08:46 PM
erb64's Avatar
erb64
Default Shift boot
Haved owned the car three years and looks like the shift boot I put in 18 months ago is rotted. Does anyone make a good one or maybe in leather?
Old Apr 5, 2012 | 09:43 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
I'm not sure how a rubber shift boot can rot in 18 months? Dr Rebuild has NOS and made in the USA repro's that should last a lot longer than 18 months.
Old Apr 5, 2012 | 10:01 PM
5thvet's Avatar
5thvet
I replaced mine about 5 years ago and it still is like the day I put it in. Can't remember is I got it at Paragon or LIC but it is rubber.
Don
Old Apr 5, 2012 | 10:06 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
http://forums.corvetteforum.com/c1-a...hift-boot.html
Old Apr 6, 2012 | 11:08 AM
rick piras's Avatar
rick piras
Sky65,
That looks like a good solution, can you show us how you attach the boot? I'm also running a tremec 5 speed, and the stock rubber boot doesn't really work. Did you attach the boot to the bottom of the console, and then slide things into place?
Thank in advance,
Rick
Old Apr 6, 2012 | 12:08 PM
Sky65's Avatar
Sky65
This is the boot I used. I actually got the idea from another post on the forum. Note the hard band around the perimeter of the boot on the bottom. That fits under the console and around the boot opening. It a little bigger than the opening so the rectangular shape is not an issue. It is held in place when the console is reinstalled. They are available in multiple colors.
There is also a vendor that advertises shift boot specifically for midyears here on the forum. I don't know the cost.
Old Apr 6, 2012 | 12:18 PM
rick piras's Avatar
rick piras
Ahhh, I get it now! Thanks, you just solved one of the issues on my project, that only leaves another 150 to be solved.
Thanks again,
Rick
Old Apr 6, 2012 | 01:15 PM
Sky65's Avatar
Sky65
Thanks again,
Rick
Let me know when you finish. You can come over and help me get my 150 done!
Old Apr 6, 2012 | 08:44 PM
erb64's Avatar
erb64
Great idea. Thanks
Old Apr 6, 2012 | 10:00 PM
davewh's Avatar
davewh
I did the same thing, replaced my boot about 18 mo. ago and it roted in less then a year. I then bought one from a different place and it is fine.
Old Apr 6, 2012 | 10:32 PM
americanretrodave's Avatar
americanretrodave
I remember in ‘69 taking my date to her prom in my ‘58. The boot was cracked, the blow-by of that two-four barrel, 098 cam, 283 was focused on joining us. My date quickly commented on it‘s arrival, I hastily told her not to worry. She then pointed out that she was afraid the smoke would ruin her dress. Without missing a gear, I said ‘Shhhhh, it’s a Corvette, don‘t let her hear you!”. It wasn’t mentioned again.
To Shift boot
