pointless ignition
Old May 26, 2012 | 02:33 PM
frankgv's Avatar
frankgv
Default pointless ignition
Hello and Happy Memorial Day weekend where we remember those who made it possible for us to have this occasion.
I have an Accel pointless ignition in my 64 327, that replaced the original point ignition.
It was put in by a friend some time ago, my question is what is the correct package for this car even if not an accel. Is anyone using a succesful set up with coil and or value of ballast resistor.
Thanks, Frank
frankgv@att.net
Old May 29, 2012 | 01:00 PM
corvette62's Avatar
corvette62
Default Corvette 62
Thanks, Frank
frankgv@att.net
I installed an Accel ACC-2010 points eliminator ignition on my 62 during restoration approximately fours years ago. It has performed well. I am using Accel coil # ACC 8140 C which is an Accel match. It does not require a resistor in series with the 12 volt ignition wire Available thru Summit Racing
Old May 29, 2012 | 01:11 PM
62Jeff's Avatar
62Jeff
In another thread you had asked for part numbers to implement a pointless conversion.
http://forums.corvetteforum.com/c1-a...onversion.html
Are you looking to replace your Accel system, or now are you thinking about just working with what you have?
Old May 29, 2012 | 01:20 PM
billsc1's Avatar
billsc1
Eliminated the dual point set-up on my '62 and went with the Pertronix III module and matched coil. Easy install (no resistor) runs great with no issues whatsoever!
Old May 29, 2012 | 03:11 PM
Mike Ward's Avatar
Mike Ward
Being dyslexic sometimes results in my reading some stuff that's not really there, or was that just a double entendre?
Old May 29, 2012 | 03:19 PM
rustylugnuts's Avatar
rustylugnuts
So what we are really saying: Electronic ignition systems are pointless......
rustylugnuts
Old May 29, 2012 | 05:08 PM
mrg's Avatar
mrg
The first time around I read 'pointless conversion' as 'pointless conversation'. .. This is what happens when you get OLD.
Old May 29, 2012 | 09:08 PM
frankgv's Avatar
frankgv
had a lot of "red dust" on my accel unit and a dry mechanical advance. did some cleaning with contact cleaner and a little lube on the mechanical, changed the rotor and cap and is running much better, duhh.
How do you remove the mechanical advance parts from under the rotor of the delco didtributor ??
Thanks,
Frank.
Old May 30, 2012 | 02:51 AM
Pilot Dan's Avatar
Pilot Dan
Default What is the POINTs as posted previously
For those of you with stock Corvettes, I am obliged to say that if it ain't broke don't fix it. Been driving with the standard points and ignition systems (properly maintained and serviced) for the better part of 40 years now in many cars and NEVER A FAILURE PERIOD. How many posts have you read about the traditional system failing compared to all of these many forum posts about Pertronix problems???? Just sayin, if it ain't broke why do people keep trying to fix it???
Old May 30, 2012 | 08:34 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I don't know why this debate continues to re-emerge. I put a Pertronix III in my '61 2-1/2" years ago and haven't touched it it since and I drive about 5,000 miles a year.
Never had a Pertronix fail in 25 years and 6 classic cars that are actually driven - a lot.
Their ignition module is good - their coils...not so much. Points, like vacuum tubes start to deteriorate from the time you install them....and yes I've had points (and condensors) leave me stranded. Points being fault-free in perpetuity is another myth.
Old May 30, 2012 | 08:45 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Shhhhh..... Frankie. Keep it quiet. Otherwise my nearly 60 year old hallicrafters short wave receiver, with its original tubes, will hear you.
Jim
Old May 30, 2012 | 09:01 AM
RRod's Avatar
RRod
Thanks, Frank
frankgv@att.net
Here you go:
http://forums.corvetteforum.com/c1-a...post1580941821
and
http://forums.corvetteforum.com/c1-a...er-please.html
Old May 30, 2012 | 09:08 AM
Bill Pilon's Avatar
Bill Pilon
I have dual points and condenser in my 60 which I drive nearly every day, I've had it 32 years and have never had an ignition related problem, normal tune-ups and routine care and it does just fine.
Old May 30, 2012 | 11:46 AM
rustylugnuts
Just think before the electronic ignition & disc brakes there were either ten to twenty cars found dead on the side of the road daily with faulty points, or those drum brake cars just couldn’t stop, they just smacked into each other it was a crazy time..... What a mess with all that carnage..... The woman or fair minded males couldn't drive cars with manual steering they just didn't have the arm muscle to turn the corner..... Most drivers had carpel tunnel from cranking the windows.
Thank God for the advancements we have today that make cars safe, easy & run forever............
rustylugnuts
Old May 30, 2012 | 03:14 PM
JohnZ's Avatar
JohnZ
Jim
So would my old Browning Golden Eagle SSB CB base unit (and D-104 mic, 300-watt water-cooled linear, tower, rotor, and Moonrakers) and McIntosh stereo amps.
Old May 30, 2012 | 03:21 PM
Frankie the Fink
Army
Sure ... Tubes never fail. That's why part of my job in the several drugstores I worked in was to help customers with the old tube tester at the front of the store...
Old May 30, 2012 | 03:40 PM
JohnZ's Avatar
JohnZ
That was my job when I was a kid - when the 10" DuMont B&W TV crapped out, it was my job to remove all the tubes, take them to the drugstore, plug them all into the big blue tube tester, and buy replacements for the dead tubes. If that didn't fix it, my Dad had to call "Manny", the TV guy.
To pointless ignition
Old May 30, 2012 | 04:45 PM
rustylugnuts
So do spark plugs, water pumps, fan belts, radiators.... oil, the list go's on... so what's the point.... or points?
rustylugnuts
Old May 30, 2012 | 04:56 PM
Mike Ward's Avatar
Mike Ward
We were so poor when I was a kid (fill in the blank)______________________________
Old May 30, 2012 | 05:03 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i used a good old fashioned build it yourself HeathKit CD system with my points for almost 30 years with the same set of points... ( i have several extra 'black boxes' now that i'm using an electronic distributor for my EFI)
Bill
