I did a test run on body fitment with my 10 inch wide wheels and it was close on one side and the othere side could not even come close. One camber rod is adjusted out a and the other is inn. I couldnt adjust toe in on one side. I talked to a corvette dude and I am pretty sure my frame is bent. It never ends. I will try to post pics when I get them. Oh and anyone worried about body shiming the body for door gaps, dont worry. If you have any muscles it is the easiest thing ever. Toe in sucks
Cobra guys know all about asymetrical bodys where one side doesn't match the other side at all. After 40 years Corvette bodies aren't much better - after all they are just a bunch of pieces glued together. I'm not sure they were too symetrical when new. But, could be a tweaked frame too.
A ten inch wheel under a mid-year is quite a feat. Do you have stock fenders on it?
My trailing arms are brand new vette parts and brakes offset trailing arms. The wheels are 5.25 backspace and one fits perfect with about a .25 inch of room between tire and frame. This side adjusts fine and I am able to add and remove shims and get it to change toe. The other side is toed out and hiting the frame no matter what I do. I also had to adjust one camber rod completely out while the other is all the way in. When i measure the trailing to the pumpkin the side that doesnt adjust is .75 closer. The composite leaf is sitting inside the wheel too and not on the other side. The 10 inch wheels almost fit under the factory qaurters but I might get the widened qaurters to be safe. If so close I cant decide and with the alignment issue it make it hard to tell. Overall I am pretty happy with the look of the wheels on the car. Thought they where going to look to big ,but I think once the front end is lowered down and the bumpers and sidepipes on it should look good. 8.5 wide wheels fit the front no problem too.
Tom, are you running 15" wheels, and what tires are you using? How much sidewall bulge do you have (how much wider are the widest part of the tire than the wheel? I am planning to use 10" wide, 17" diameter wheels for traction and to clear brake calipers. Thanks.
About your issue. Are the inner axles into the rear housing the same on both sides? If the clip comes off the axle inside the housing, the inner axle will move in and out. This would allow the side on which you have clearance to move out. Have you done a cross corner measurement from the trailing arm bolts to the opposite rear corners of the frame? If you can't take clear measurements, a plumb bob and a marker used on a clean floor will get you in the ballpark. This will tell you how square the area of the frame is where the problem is occuring. Just a couple of ideas for consideration. Good luck to you.
My wheels are 20x 8.5 front and 20x10 rear. The backspace is 5.25. I wish I would have gotten a coulple sizes smaller in diameter but hopefully when lowered it will look nice. I dont have the half shafts in but I didnt think that would make a difference. I was talking to my mom whom was there when I pulled the body and whom owned the car for the past 40 years and we are sure that it was like this from the start. I am not sure how the one side ever had the toe adjusted. This car was wrecked when it was near new and doesnt have the correct year frame. I have been finding all kinds of rig jobs on this thing. Thanks for the help.
My frame is a factory 65-67 that I have fully welded,gusseted, and reinforced. The leaf spring is a vp and b 360lb composite. The trailing arms are vp and b offset.
I didnt know the haft shafts made a difference. I would think that if they some how hold the suspension to any position that would be bad. Wouldnt that be putting them at a bind or putting stress on them? What be good haft shafts? I was looking at the nitous ready shafts from dennys driveshafts. Are they much better than heavy duty factory one. Price is $160 vs. $230.
You don't list where you are located. If near central Florida, Artie at Van Steel has a c-2 and c-3 frame jig at his shop in Clearwater. He picked up mine at my house in Tampa. His crew sand blasted it and made sure it was within specs and powdercoated it. The frame was delivered back to me a few weeks later, factory fresh and clean. Jerry
I am located in des moines iowa. The guys at vansteel are super nice though. I talked to them when trying figure out the backspace on my wheel set up. I measured from the trailing arm to the pumpkin and one is a half inch closer. It is like the
hole in the pocket isnt straight or needs drilled differen
thanks... i didn't know that you could fit a 10" wheel on a stock C2.
Bill
Well guys this is why I love this forum. If you guys think that the factory shafts will be good I would be more than happy to save myself a ton of money. I dont plan on being too hard on it but I had my uncle in my ear telling me how he broke a shaft everytime he drag raced his 64 vette. He ended up putting a solid axle under it. As far as the trailing arm goes it seems like the bolt hole in the pocket could be changed a hair and fix all my problems. Any thoughts on this or is this a crazy idea. I completely wraped the area with 1/8 inch steel but drill the holes perfectly where they where. I know you would Not want it slotted but if one sides hole was moved a smidge it would put my arm where it needs to be. Here is a pic befor powder coating and grinding.[IMG][/IMG] This is the day I brought it home from the powder coater.[IMG][/IMG]
Not a great pic but an idea of 10inch wide wheel on back. Probably need widened qaurters to do it right. Close though with 275/30 tires.[IMG][IMG][/IMG][/IMG][IMG][/IMG]
The location of the trailing arm front pivot bolt has nothing to do with the track width or tire-to-fender clearances; the only thing that determines track width is the length of the half-shafts and the lower strut rods - they're the upper and lower control arms for the rear suspension.
