Dial Back Timing Light
Old Jul 17, 2012 | 02:37 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Car runs fine
Old Jul 17, 2012 | 02:49 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Frank, If your balancer is correct to the motor, and you want/need it rebuilt, I can vouch for Damper Dudes in Ca. 800-413-2673. The cushion on mine was looking bad, so I had them rebuild it...just like new. Dennis
Old Jul 17, 2012 | 04:07 PM
Frankie the Fink
Army
Thanks... I want to verify some more things before I start unbolting engine parts !
Old Jul 17, 2012 | 04:26 PM
mkh's Avatar
mkh
frankie I am sure you know you can rotate the distributor to any orientation as long as the wires are also rotated. Check the timing with wire connector on the #8 cylinder and it should read fine.
Old Jul 17, 2012 | 04:42 PM
Frankie the Fink
Army
Yes I do know that...with the induction pick up on the #8 wire...I can't even see the timing mark on the balancer as it is w-a-y off counter clockwise somewhere.
Old Jul 17, 2012 | 04:47 PM
Westlotorn's Avatar
Westlotorn
I second the motion, good shop has been reliable for years. I have not talked with anyone that came away upset with the Damper Dudes.
Old Jul 17, 2012 | 05:08 PM
steampunk c1's Avatar
steampunk c1
Try the induction pick up on number 6. its 360 degrees from number 1
