I have an Actron dial back timing light I've used for the past five years. When I put it on the 283ci '61 Corvette and crank the reading back to align the marks at TDC I get the correct 12* (with vacuum advance plugged).
The same timing light on the 396ci '67 Chevelle (with vacuum advance plugged) and the light dialed back to TDC gives me 38*. Driving me nuts. The '67 has an HEI distributor and is running on ported vacuum with a rock steady vacuum at 750RPM idle of 19". The spec for the motor is 4* initial timing.
The only thing I can figure is that the timing mark on the balancer is way off.
Number 1 cylinder is the frontmost one on the driver's bank on both engines ... right ?
Any insights ??
So the first one has 12* and the other has 38* initial.. Not sure what I'm missing?
The timing light reads correctly on the Corvette at 12* it does NOT read correctly on the Chevelle -- should be approx 4* for a 396ci/375hp engine when dialed back but reads 38*...
Are you sure your centrifugal advance isn’t kicking in even at idle? Try JohnZ’s trick (from his timing article) of using a rubber band wrapped across the weights to make sure they’re not moving. Otherwise, I don’t know why the light would read differently on that engine. I always have trouble with my dial back timing light turning on me???
I don't see how I could have full advance at 750RPM if the dizzy springs have any tension at all but I'll still check. The car runs out great. I also think I have a regular old 'dumb' timing light buried in a cabinet somewhere I may dig out to verify readings. Now I'm wondering if somebody re-clocked the distributor on me (which I'll also check tomorrow).
Not at this point. I'm gonna start from scratch tomorrow. Find TDC on the compression stroke...see which dizzy tower the rotor is pointing to...and go from there...
Frank, Don"t let this get away and turn into an engine rebuild. Dennis
You know Dennis the engine is much easier to access with the body off the chassis! And the body is easier to remove with all that interior and glass out of the car
The distributor housing is rotated about 45* clockwise from the stock location, but more strange, with the timing marks at TDC the rotor is pointing at the #8 spark plug tower and the wire from that tower does indeed go to the #8 spark plug.
Either the #8 piston is also at TDC when the marks align (or the car wouldn't run) or the balancer mark is off.
