harmonic balancer question........
Old Aug 6, 2012 | 01:11 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Default harmonic balancer question........
Is there a way to tell by looking at a balancer, off the car, if it's slipped on the hub or has deteriorated to the point where it needs to be rebuilt?
Thanks.
Old Aug 6, 2012 | 01:23 PM
JohnZ's Avatar
JohnZ
Thanks.
Yes. The timing index line on the outer weight should be exactly in line with the keyway slot in the hub and a pulley bolt hole if it hasn't slipped.
Old Aug 6, 2012 | 01:44 PM
midyearvette's Avatar
midyearvette
john is correct but there were some years in the seventies where the mark did not line up with the index key....we are talkin' small blocks here.....they moved the timing tab up and had to move the mark for timing light purposes....
Old Aug 6, 2012 | 02:05 PM
JohnZ's Avatar
JohnZ
That happened in 1969 when the passenger cars went to the "long" water pump and passenger-side alternator mounting; the timing index line was moved 10* counter-clockwise on the weight, and the timing tabs on the timing cover moved to match. However, the Corvette didn't change - it stayed with the "short" water pump and timing index line directly aligned with the hub keyway.
Old Aug 6, 2012 | 02:10 PM
midyearvette
i have worked on numerous corvette small blocks built in the seventies john, and yes, my good friends 77 corvette indeed had a balancer keyed with the timing mark not aligned with the index keyway and a higher placed timing tab and indeed it was the original motor since he bought it brand new, also the engine was painted blue from the factory.....
Old Aug 6, 2012 | 02:26 PM
JohnZ's Avatar
JohnZ
I don't doubt that - it might have changed sometime after '74; I've never worked on one later than '74.
Old Aug 6, 2012 | 03:13 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Since it is highly probable that any SBC has been rebuilt or modified, it is always best to find TDC anew. Of the two harmonic dampers I've commonly found, the TDC mark is either inline with the keyway or 10 degrees CCW. If it is not at either, I reject the HD.
Old Aug 6, 2012 | 04:43 PM
Kerrmudgeon
that's great info Frank and John. Can you tell by looking at the rubber between inner and outer ring if it has deteriorated?
This balance was bought used, an 8 in, so I don't know what it's off off or year. So I take it it's either lined up or 10 degrees off to the left from the front, right? Anything else means it's slipped and useless?
edit: OK so I have one 8 in. and the line is approx 5/8th of an inch to the left, and a 7 in. that's lined up perfectly. Are they both good?
Old Aug 6, 2012 | 05:00 PM
midyearvette
dunno...haven't used a rubber in years....i would be leery of the 8 incher, unless it came on a 70's or so sbc....
Old Aug 6, 2012 | 05:09 PM
Kerrmudgeon
Neither have I.
So 10 degrees isn't 5/8ths of an inch then I take it? No idea what it's from or year. Part #3898966, and 213 79 and H2222 on the flip side.
Old Aug 6, 2012 | 05:21 PM
midyearvette
Neither have I.
you will have to do the math to see what measurement is 10 deg....and on what size balancer....all i know is the ones i have seen were not 8" but that does not mean they did not make them
the timing covers are different also...the tab is mounted a lot higher than the usual standard one...good luck...
Old Aug 6, 2012 | 05:59 PM
MikeM's Avatar
MikeM
Sounds right to me.
Also, I'm pretty sure the '79 C 10 truck I had, the timing pointer was at 12:00. Straight up at the top and the timing cover pointer was like a piece of round tubing that you shot the light through to set timing.
Old Aug 6, 2012 | 06:08 PM
Kerrmudgeon
So the math works out to .71 is 10 degrees, and that's around 5/8th of an inch, so it looks like it's good. Now, the rubber shows tiny hairline cracks going around the perimeter.....is that normal?
Old Aug 6, 2012 | 07:55 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
kinda sorta...
Bill
Old Aug 6, 2012 | 08:15 PM
MikeM's Avatar
MikeM
For a new one, no. For a used one, very normal.
I'd be concerned if chunks of the rubber were herniating out from between the hub and outer ring.
Old Aug 6, 2012 | 09:02 PM
Kerrmudgeon
Originally Posted by wmf62
kinda sorta...
Bill
...thanks for the definitive answer Bill!
To harmonic balancer question........
