Shocking question
Old Aug 6, 2012 | 11:21 PM
fred kay's Avatar
fred kay
Default Shocking question
I currently have a 65 small block coupe that has a composite rear spring with a tag on it that says 300lbs. It has KYB shocks all around. The vette rides real nice but is a little too bouncy and soft in the rear. Front is real nice and tight and kind of stff . I would like to get the rear to feel the same while keeping composite spring. Any suggestions for what shock to use to stiffen the rear up just a little. Thanks
Old Aug 6, 2012 | 11:27 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I would change the spring to the 330#. Dennis
Old Aug 7, 2012 | 02:38 PM
JohnZ's Avatar
JohnZ
Whether you stay with the 300# spring or go stiffer, in either case you need rear shocks calibrated specifically for the composite spring, with more rebound damping than "standard" shocks. There's no interleaf friction with a composite spring, so the shocks have to compensate for that, or the rear suspension is "bouncy". Vette Brakes has the shocks.
To Shocking question
