Pertronix Ignotor
Old Sep 13, 2012 | 08:30 AM
RedOrDead's Avatar
RedOrDead
Default Pertronix Ignotor
Anybody using a Pertronix Ignitor?
Noticed any real improvemnts?
Theres 3 models, 1, 2 and 3.
I am looking into getting one fitted, but I need to get the numbers of my existing distributor so that I know which kit to buy but i cant seem to find any identofying numbers on my existing distributor.
Does anyone know where exactly the numbers are on a '64?
Chris
Old Sep 13, 2012 | 09:01 AM
oldsarge's Avatar
oldsarge
I use Pertronix on both my 64 and 73, I find they are doing a great job, alot better than the old points and condenser. They fit a wide range of distributors, I dont think it matters for any one specific year.
Old Sep 13, 2012 | 09:54 AM
toms silver 60's Avatar
toms silver 60
If you go to the catalog, there is only one application for V8 Chevrolets. I prefer the Ignitor III as it mounts lower and doesn't need a "perfect" distributor weight mount- Mine had some wobble which changed the clearances which were supposed to be .010-.020 inches if memory serves me correctly. My Ignitor I had more than that at high "wobble". Plus you have more protection with the II and III.
Yes, I do carry a spare distributor and coil "just in case", just like my space saver spare tire.....
Old Sep 13, 2012 | 10:24 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
The numbers are something like D100700 .... Same for BB and SB motors...Kegs is a good source.
Old Sep 13, 2012 | 10:45 AM
toms silver 60
Default Kegs?
You're getting up too early.....Maybe you were thinking about some good beer, instead of that yellow stuff you drink. Or, you meant Jegs......
Old Sep 13, 2012 | 10:48 AM
Mike Ward's Avatar
Mike Ward
If someone notices any 'improvement' in performance, this simply indicates that the pieces they removed were worn out or misadjusted. The pertronics unit or similar has no magic voodoo technology that can exceed 'stock' performance
Old Sep 13, 2012 | 11:00 AM
tuxnharley's Avatar
tuxnharley
I think the RPM limit capability of the III exceeds the ability of the stock technology................. But, in a sense you may be semantically correct, as it's not "magic voodoo technology". it's just electronics and programming!
Old Sep 13, 2012 | 12:26 PM
63Corvette's Avatar
63Corvette
Yeah, what he said. My car is a RACE car, which sees consistent revs above 7000rpm. Points just don't make it. Only Borg Warner A112 points are even capable of 7000. So if your car is a cruiser or trailer queen, points are fine (altho you will have to maintain them), OR you can use your car as God and Zora intended, use modern electronics and never worry about them
Old Sep 13, 2012 | 12:49 PM
tuxnharley's Avatar
tuxnharley
Just to be clear - because in rereading my first post it seems I wasn't - I was referring to both the ability of the Pertronix to rev higher than points if you engine is built to do so, AND the ability of the III to have a rev limiter if your engine is not built to do so.
That clearly exceeds the capabilities of the stock set up -- both ways!
Old Sep 13, 2012 | 04:56 PM
fullmonty's Avatar
fullmonty
Just adding my 2 cents worth, do not purchase the coil, I've had two units with below satisfactory output.
Old Sep 13, 2012 | 07:35 PM
bighouse's Avatar
bighouse
I put one in everything. Love it!. I have pertronix I currently in my 63 corvette, old vw bug, and my dads '72 kick start big twin harley. BIG improvement in starting with all. Sometimes they sit for a long time and start right up, no fiddling.
Old Sep 13, 2012 | 07:57 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Old Sep 13, 2012 | 08:06 PM
NOM61's Avatar
NOM61
Love the Pertronix Ignitor III in my 302. Rev limiter works like a champ. One thing not mentioned so far is that the III also has full rpm range multi-spark. So that's three clear improvements over the stock point ignition - max rpm limit, rpm limiter and msd.
DT
Old Sep 13, 2012 | 08:47 PM
Frankie the Fink
Army
I run an Accel hi-performance coil with the Ignitor III and its a real nice combo.
As far as improvements -- anything that keeps me from having to dick around with the ignition shielding is an improvement...
Old Sep 13, 2012 | 08:49 PM
62Jeff's Avatar
62Jeff
Pfft, typical response from a lazy employed person.
Old Sep 14, 2012 | 11:18 AM
RedOrDead's Avatar
RedOrDead
My car already starts and runs fine, no issues there at all. Its just that with regular use the car needs a tune up almost monthly.
I have been advised that the Pertronix would go some way to keeping the car in tune for longer.
I mean in London we only get about 6 weeks of summer at best, during that perod I do my best to use the car every 2 days and I hate having to send the car away for tune-ups when the sun is shining and I am left to use the BMW.
Hopefully the pertronix will mean the car can spend more time on the road.
Old Sep 14, 2012 | 11:27 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
You are definitely doing it wrong if you think you need monthly tuneups.
To Pertronix Ignotor
Old Sep 14, 2012 | 11:37 AM
RedOrDead's Avatar
RedOrDead
Ok, lets put it this way, with regular use, once every few weeks the car starts to run a little lumpy, idle is not so great, exhausts pop a little. If ignored it gets gradually worse. I send it off to one of the very few Classic American specialists in the UK and it comes back perfect again and I am charged for a "TUNE-UP".
Old Sep 14, 2012 | 12:59 PM
Kerrmudgeon
Sounds like they have a good business plan! These old cars used everyday get 10-15,000+ miles of reliable service between tuneups. You must remember that the same motors powered a good percentage of family cars on the road back then.
My limited use 62 has the same accel points, cap, rotor, etc. that I installed about 20 years ago. Starts right up and purrs like a kitten!!
Old Sep 14, 2012 | 01:41 PM
Frankie the Fink
Army
Somethings not right.....
My original '61 dual quad, solid lifter car runs so good anymore that I hardly ever raise the hood unless I'm at a show and that's putting about 4,000 miles on it annually.
