60 front end replacement
Old Oct 10, 2012 | 02:34 PM
osubaka's Avatar
osubaka
3rd Gear
Default 60 front end replacement
We are looking to replace the front end on a 60. I've looked at both the hand laminated and press molded front ends from ecklers and i've looked at the one produced by Back to the Future products.
Which do you guys have experience with?
Which fits best and has the overall better quality?
Are there any other brands to consider i haven't mentioned?
Old Oct 10, 2012 | 05:31 PM
mike coletta's Avatar
mike coletta
If you want "fit" Sermersheims is the only way to go. If you want "price" then everything else goes there. The two will not connect.
Mike Coletta
Old Oct 11, 2012 | 11:12 AM
John McGraw's Avatar
John McGraw
I agree with Mike. Press-molded front clips will always fit better, and cost more. I use press-molded parts even on resto-mods.
You can save some money on hand-laid parts, but the labor will be more, and any buyer in the future, with any knowledge, will discount the price of the car for using hand-laid parts. There are only two companies making parts that appear like original press-molded parts, Semerschiems, and Corvette Image. Neither of them actually makes press-molded parts, as the original press-molded parts were actually made by two, metal, steam-heated dies, pressing the resin and mat, while it cured. The current parts being sold are actually made from a 2 piece mold, that leaves a finished appearance on both sides of the part, and controls the thickness of the part. The backside of these parts look very similar to original parts, while hand-laid parts can be instantly identified by look at the backside.
In my opinion, the hand-laid parts are not a good value, even at the reduced price.
Regards, John McGraw
Old Oct 11, 2012 | 11:15 AM
John McGraw
Mike Coletta
Mike,
Reminds me of the sign in many shops:
CHEAP
FAST
GOOD
Pick any two!
Old Oct 11, 2012 | 12:32 PM
osubaka's Avatar
osubaka
3rd Gear
Thanks for the info. I appreciate the input.
Maybe i should have explained a little better, but tell me if this would influence your decision at all.
We do not care about originality of the car. The client is customizing the car, so as far as originality, we are not even remotely concerned. We intend on doing any bodywork necessary to make the car perfect, and considering that, would you still only go press molded where it doesn't matter if the underside is smooth?
Are the press molded parts SMC or just press molded normal fiberglass? Not really interested in using SMC due to the impregnated release agents in the fiberglass.
Any thoughts?
Old Oct 11, 2012 | 12:59 PM
John McGraw
Any thoughts?
Yes, I use the "press-molded" parts, even on customs.
The parts are fiberglass and not SMC. There are really not any press-molded parts being made these days. They have not made any for 40 years. All of the parts are molded, the "press-molded" ones are just done in a two-sided mold. The fit of the "press-molded" parts is just enough better, in my opinion, to justify using them. you can make any part fit with enough labor, but Semerschiems, and Corvette Image parts will fit better than the hand-laid parts available. You are also probably comparing apples and oranges when you compare the two options. The hand-laid front clip will most likely only be the outer glass and will not include the inner fenders. You will still have to purchase inner fenders and grind and fit them to the hand-laid clip. The jig-assembled front clips from Semerschiems and Corvette image will be ready to install on the car, with minimum work.
I think that most buyers will discount the value of the car at a future sale, because of the hand-laid glass, I know I would.
Old Oct 11, 2012 | 02:19 PM
mike coletta
CHEAP
FAST
GOOD
Pick any two!
John......that's funny. I'm going to start using this when I bid a job!!!
Back to the OP.....I agree with John. Unless you're getting labor for free, you'll be money ahead by using the "smooth both sides" parts. You, or your bodyshop will save a ton of time. I also agree with John that you'll be discounting the value of the car if you use a hand laid part.
Mike Coletta
Old Oct 11, 2012 | 03:15 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Originally Posted by John McGraw
Mike,
CHEAP
FAST
GOOD
Pick any two!
Those 3 parameters are called the Iron Triangle of Project Management... The "pick two" concept is not only taught in most PM courses its actually true !!
After watching Mike tackle massive body makeovers for his restomods I can't imagine it makes ANY sense to 'cheap out' on sub-par body parts. I'm no body guy but its false economy...every dime you save on the part you are going to give back (in spades) on labor and STILL might wind up with a mess.
Old Oct 11, 2012 | 07:47 PM
osubaka's Avatar
osubaka
3rd Gear
ok thanks,
I am building the car for a customer and will be doing the body and paint. We do extensive customs so either way should't be a problem. But we're not using the factory inner fenders and are going to coat the underside of the body anyway so most of the typical things people worry about (original seams, colors, smooth underside, etc.) are not important. I'm not that concerned about gaps as much because i can fix those easily. i'm more worried about bigger issues that you can't see in a part til it's bolted up- sway in the part, hood opening size, dimensions being proper, grille openings etc, droops in fenders. Basically all the things that aren't exactly visible when the piece is sitting on the ground. Only when you bolt it up you see that the things that need fixing are very hard or impossible to fix without cutting or major glass work.
Old Oct 12, 2012 | 06:51 AM
aworks's Avatar
aworks
I put a Corvette Image one piece hand laid nose on my 62. I never had a nose fit so perfect. It literally dropped in place.
I've installed many press molded nose's from CI and Semerschiems over the years and agree the press molded are nicer parts but some cars don't need them.
I use CI parts all the time and have never had any problems. Now not long ago a good friend that dose just restorations and has hung more midyears body parts than most, put a Semerschiems nose on a 67 and it was so poor he called me to come look at it. Maybe someone had a bad day or the fixtures are getting old but that nose was a POS.
Try a CI one piece.
Old May 24, 2013 | 07:37 PM
bert54's Avatar
bert54
Cruising
Can anyone help. Is this a job for a novice? What should you expect to pay to have a one piece frontend installed.
Old May 24, 2013 | 08:38 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
well, i used an Ecklers (back from when they were doing their own) hand laid frontend and i would admit that it had some problems, but the price was right and my labor was free... you be the judge..
btw, handlaid pieces are usually thicker and therefore have better strength
Bill
Old May 23, 2014 | 07:07 AM
mickatbp's Avatar
mickatbp
Does some one have photos of the hand laid and pm panel undersides? How uniform are the hand laids parts? What makes them so easily identifiable ... is the resin content too high, is it just the color of the panels, is too rough???
To 60 front end replacement
