Engine Offset
Old Dec 21, 2012 | 10:36 AM
MikeM's Avatar
MikeM
Here is more if anyone cares to read it:
http://jniolon.clubfte.com/driveline...nephasing.html
Old Dec 21, 2012 | 10:45 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by Ironcross
this is what I thought, and BB`s are even a little more offset than the SB`s
........but, wharever
Frames and diffs are identical for SB and BB. Same offset.
Old Dec 21, 2012 | 12:57 PM
JohnZ's Avatar
JohnZ
'67-'69 Camaro big-blocks were offset 1" to the right, for clearance between the left exhaust manifold and the steering gear. From:
http://www.camaros.org/engine.shtml#EngineMounting
<<In order to gain engine compartment clearance, big block (BB) engines were offset 1 inch to the right (towards the passenger side) by means of asymmetric brackets. 1967-68 BB frame mount brackets are 2-1/2 inches wide (but not the same as SB) and use the same engine mounts as 67-68 302ci and 350ci. For 69, BB frame mount brackets were redesigned to use the new thicker, narrower, engine mount also used by 302ci and 350ci. BBC bracket pairs are easily spotted because the left bracket is noticeably taller than the right in order to achieve the engine offset.>>
Big-block Camaros also used unique transmission crossmembers with the trans mount holes offset to the right.
Old Dec 21, 2012 | 10:43 PM
Hitch's Avatar
Hitch
When I cut off my engine mounts to straighten out the alignment of my motor in the frame I found that the offset is actually 7/8ths of an inch.
David
Old Dec 21, 2012 | 11:01 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Yeah because 800 pound race driver will fit in a mid year
The engine's offset only shifts about 15 pounds to the right side of the car.
Old Dec 22, 2012 | 02:11 AM
TCracingCA's Avatar
TCracingCA
Default Smokey Yunick and his Elfs snuck in after everyone went home!
Mystery solved.
