Ok, I think this topic has been discussed before, but at the risk of sounding dumb here goes.
Has anyone noticed that thier engine sits slightly offset to the right hand side of the frame when mounted to the motor mounts? It's been bothering me for the last 16 years of my build, but I was never sure what I was dealing with. Now that I'm a little closer to finished, body is on and sitting straight. I went to set my engine hood on and noticed that the center of the engine is about 1"-1.5" offset to the right, maybe as much as 2". My frame is straight and shows no signs of any damage.
Anybody have a similar experience?
If I remember correctly, the engine is offset from the rear end to ensure the bearings in the U joint rotate. If the engine and rear end are lined up the needle bearing would stay in one place and wear out sooner.
To compact the car more, the engine was offset to the passenger side to allow an extra inch of room for the driver's feet. This was done in 1963 when switching to the Sting Ray body.
I am thinking this is the main reason for offsetting the engine in certain models.
I think it was all of the above. We engineers are remarkable at making one change and solving a multitude of problems. We're just terrible at explaining it to anyone.
jmo... i think it easy to explain and all the other reasons could be just marketing fluff ie. driver comfort and so on
the halfshafts had to be the same length from side to side so the geometry of spring rate suspension travel and im' sure other physical issues would be uniform from side to side...to do that the carrier had to be centered in the frame and pinion offset had to be ignored but compensated for with crank center alignment to the pinion by fudging the engine over the same distance. why the frame was not widened is a mystery to me but wdik??.......
this is what I thought, and BB`s are even a little more offset than the SB`s
........but, wharever
How do you figure that one?
The pinion offset to the right,tunnel clearnce for the driveshaft, increased driver foot room for the gas pedal, increased tunnel clearance for shift linkage and brake booster clearance (BB) all would dictate offsetting the engine to the right a little.
Like I said above, it was not just Corvette that did this. Also included Chevy II, Nova, Camaro and I think Chevelle. It wasn't a Corvette specific thing.
Maybe, but I don't think so.
A 66 396 4 speed super sport, the engine and trans was definatly centered, as i remember on the 12 bolt rears one axel was shorter than the other (9 bolt fords and C1s and 55 to whatever into the 80s chevys all had different lenght axels.)
The chevyII had no room to offset the engine.
I did several v8 vega conversions back in the 70s, I always centered the engine because the pinion on the rear axle was centered.
Sorry, but the engine mounts and mount plates to the frame are mirror images on both sides on almost all cars.
Only with the C2 C3 vettes is this is untrue, look at the engine mounts that are welded to the frame, the DS frame mount is longer and the PS frame mount is shorter. My buddy Dokk did not know this. I had fun with him. I told him his car had been hit and totaled sometime in it's past because the engine was offset so much. I then smiled and Dokk learned...
As I said, not sure about Chevelle but the '62-'67 Chevy II, 4 cyl., 6 cyl and V-8, and BB "68/later Nova, BB '67/later Camaro ALL had the engine offset to the right!
In the case of the early Chevy II, you'd for sure have chassis clearance problems on the left side with V-8 exhaust, maybe clutch linkage, oil filter clearance and shift linkage clearance whether it be for a column three speed or floor mounted four speed unless you wanted to crowd the drivers feet by moving the tunnel to the left instead of moving the engine to the right.
If you try to mount a BB engine in a Nova or Camaro using the small block frame mounts (which are centered), you'll find the engine sit's too high and fights the steering box and brake booster for the same real estate. That's why those frame mounts drop the engine and shift it to the right. The transmission crossmember mounting holes for these respective engines also display the offset.
I'm pretty sure the early Mustang and Falcons also had engine offset to the right.
