non ethonal fuel
Old Jan 7, 2013 | 07:53 PM
6242's Avatar
6242
Mikes
I know what happened, and I know what caused it. Check out the use of ethanol gas on marine engines that are not ethanol approved. You are absolutely told not to use it because of the damage to rubber parts. I have rubber parts and I know what destroyed them. If this is against your thinking, so be it. I corrected the problems with a total cleaning and rebuild so I won't put a drop of that stuff in my tank again. I always used straight regular gas and sometimes added an octane additive. As to this happening before ethanol was added, do you think that additives (not refinery added) used to prevent gas line freeze up could have something to do with it? Who knows? We all have opinions, and unless you have experienced it, you will never know.
Happy motoring to all.
Old Jan 7, 2013 | 08:11 PM
65tripleblack's Avatar
65tripleblack
Originally Posted by devildog
Gentlemen,
You are starting to sound like that bunch of vicious boys on the C-3 Forum
The Brain Busters: Anderson and Blanchard.
Old Jan 7, 2013 | 08:53 PM
Mike Ward's Avatar
Mike Ward
But I've been there, done that 20+years ago, found out that the sky is not falling and got on with my life. You guys that are stuck in the position need to move on too instead of whining.
If you have old old lines on your car, change them. They're overdue evilanol or not.
Old Jan 8, 2013 | 12:51 PM
noonie's Avatar
noonie
In most areas you can still get non ethanol at marinas, and a lot of gas stations also have it as their premium gasoline.
