C1 Frame Issue?
Old Feb 27, 2013 | 12:01 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
it would be the top & bottom spacing of the fan in the shroud that would be the concern as far as hood height relative to the engine position.
Bill
Old Apr 2, 2013 | 07:43 AM
blackvette58's Avatar
blackvette58
Problem solved: The front coil springs were incorrect. They were 14 1/2" in height and the coil diameter was approximately .589. Replaced them with the correct coils: 13 1/2" and .55. Followed the instructions for installation in the assembly manual and used both a jack and a steel rod for safety purposes. When removing and installing the A Arm bolts, and achieving correct alignment when reinstalling the A Arms , the flexibility of alternating support from jack to supporting rod was very helpful and secure. After the coils were installed, I shimmed the radiator support and other body mounts to attain hood closure and a level body. Many thanks to all who responded with helpful guidance.
Old Apr 2, 2013 | 08:24 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
well, congrats... but i still don't understand what the front coil springs have to do with how the body sits on the frame or engine height..
Bill
Old Apr 2, 2013 | 09:23 AM
blackvette58
Once the correct springs were installed the nose lowered considerably thus providing a more level body contour on the frame for shimming. I shimmed the radiator support mounting a good 1", which together with additional shimming of other body mounts, raised and leveled the body properly on the frame. To do so, I had to remove the bumpers and disconnect other parts from the body to the frame so that the frame would not raise...just the body.
Old Apr 2, 2013 | 10:29 AM
narlee's Avatar
narlee
Glad to help. Now you can move on to the next step and get on the road.
