Another PCV question
Old Jun 18, 2002 | 04:20 PM
59er's Avatar
59er
Default Another PCV question
Hi Guys,
I,ve been watching this subject and have now set up my system.
My question is do I need to have baffle plates under the PCV and relief valves?
The valve covers that I am using had the knock outs but no baffles under them. They do have small bosses that I imagine are for mounting the baffles.
How critical are they and what are the possible problems associated with not having them.
Thanks, Mark.
Old Jun 18, 2002 | 04:32 PM
SWCDuke's Avatar
SWCDuke
Default Re: Another PCV question (59er)
Generally you need some sort of "liquid-vapor" separators at the valve cover connections to keep the engine from ingesting oil through the PCV system. It's most critical on the downstream side - valve cover outlet to PCV valve to carburetor port. Take off the lines and check the valve. Do they have evidence of liquid oil in them?
Duke
Old Jun 18, 2002 | 04:35 PM
Mark Lovejoy's Avatar
Mark Lovejoy
If you run it without the baffles I would be concerned with the PCV system sucking in oil and fouling your PCV valve. If the valve covers have accomodations for them I would fab up some sheet metal and screw them into place. Don't forget to put a little red loctite on the screws.
Old Jun 18, 2002 | 04:42 PM
Kid_Again's Avatar
Kid_Again
Default Re: Another PCV question (Mark Lovejoy)
...order moroso pn 97340, baffled valve cover grommets, coupla' bucks
thanks johnZ :seeya
Old Jun 18, 2002 | 04:50 PM
Guest
Guest
Posts: n/a
Default Re: Another PCV question (Kid_Again)
thanks johnZ :seeya
I second that. You can find a baffled grommet at most parts stores. There are two type of PCV systems, a positive PCV system and a closed positive PCV system.
The positive simply uses a PCV valve to extrace crankcase ventallation. The air is replaced through a vented oil cap.
The closed positive system replace the vented oil cap with a connection to the air cleaner.
Either are WAY better then none. Thanks to the folks here for the recent help.
David.
Old Jun 19, 2002 | 02:31 AM
59er's Avatar
59er
Thanks guys,
I haven't run the motor yet to see if the oil would be a problem and before the rebuild it had the pcv in a grommet in a vented cap so I doubt that it worked as I would imagine that it would just short cycle and it used to dump to the ground.
I will check out the baffled grommets or at the least fabricate the baffles in the valve covers.
Thanks again for the input, Mark.
To Another PCV question
