Differential
Old Jun 18, 2013 | 07:01 PM
Nick6365's Avatar
Nick6365
Default Differential
I have what I believe is a 63 differential. I can not read the numbers. When I turn the drive shaft by hand both axles rotate in the same direction. If I hold one axle the other will continue to spin. When I turn one axle the axle the other turns in the opposite direction. Without taking the differential apart can anyone tell me if this is a slip differential? Thanks
Old Jun 18, 2013 | 07:37 PM
MrPbody's Avatar
MrPbody
If it was originally limited slip (most likely was) it isn't now.
get in a parking lot and do tight turns one way then the other for a wile. it may help,…… but more likely just makes you dizzy.
Russ
JohnZ's Avatar
JohnZ
It's pretty normal to have to clean and/or wire-brush that area in order to see the numbers.
Old Jun 18, 2013 | 09:37 PM
Nick6365's Avatar
Nick6365
Russ, The differential is not in the car-why would it no longer be a limited slip? Thanks, Nick
Old Jun 18, 2013 | 10:42 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Sounds like an open diff to me.
To Differential
