Another wiring ??
Old Jun 27, 2013 | 08:43 PM
KNIPPS's Avatar
KNIPPS
Default Another wiring ??
Ok I think this should be the last one. After getting all the wires behind the dash buttoned up on my 67 I find a dangler. I grab my Doc rebuild schematic and find it and it says it is the ignition switch lamp but....I already have a lamp there and this one is smaller and would not fit in the ignition switch housing. I find a diagram here and it says that it is the radio lamp so which is it? Thanks Jim
Old Jun 27, 2013 | 08:53 PM
ooh yeah's Avatar
ooh yeah
so glad not to be you. I just replaced every harness in the car and my head still hurts. Sorry this is no help just wanted to let you know I feel your pain.
Old Jun 27, 2013 | 08:57 PM
66jack's Avatar
66jack
Do you have the 'radio' one in or are you asking/saying it looks like the radio on in the picture?
Old Jun 27, 2013 | 09:01 PM
KNIPPS's Avatar
KNIPPS
I have that one that comes out of that part of the harness but my Doc Rebuild schematic says it should be the ignition switch bulb...this says its for the radio but I am not sure if this is for a 67 or other year
Old Jun 27, 2013 | 09:09 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Do you have the light for the cig lighter plugged in
Old Jun 27, 2013 | 09:23 PM
KNIPPS's Avatar
KNIPPS
Default Wires
Yep cig lighter is plugged in
Old Jun 27, 2013 | 09:40 PM
Nowhere Man
I was talking about the light for the cig light
Old Jun 27, 2013 | 10:59 PM
DZVette's Avatar
DZVette
Knipps,
That pic is from 65 AC coupe (Lectric Ltd. harness).
The one below shows the grouping with the cig lighter light.
The pdf file covers left end to right end of the dash harness for the 65 AC coupe.
Dave Z
File Type: pdf
Old Jun 27, 2013 | 11:05 PM
KNIPPS's Avatar
KNIPPS
Default Light
Yes cig light is attached
Old Jun 27, 2013 | 11:08 PM
KNIPPS's Avatar
KNIPPS
Yes I got the cig light attached it was on the main portion of the harness behind the cluster. What I have is a smaller bulb that comes out with the clock lights and the radio connection and I don't know what it's for. Is there a light for the radio?
Old Jun 27, 2013 | 11:54 PM
66jack's Avatar
66jack
Originally Posted by knipps
yes i got the cig light attached it was on the main portion of the harness behind the cluster. What i have is a smaller bulb that comes out with the clock lights and the radio connection and i don't know what it's for. is there a light for the radio?
yes
Old Jun 28, 2013 | 07:06 AM
kingwoodvette's Avatar
kingwoodvette
Light boss is located in Lower left near the front of the radio as I remember. Not sure you can plug it in without removing the radio.
Old Jun 28, 2013 | 07:48 AM
rich5962's Avatar
rich5962
The radio light is built into the radio and gets its power from the radio connector gray wire.(pic below of a 67 radio)
That light you're asking about is for the heater controls. It's a backlight that uses a torpedo bulb and special clip, along with a green cover for the bulb.
See this thread and a nice photo from JohnZ in post #6.....
http://forums.corvetteforum.com/c1-a...tor-light.html
Old Jun 28, 2013 | 07:56 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
See this thread and a nice photo from JohnZ is post #6.....
That's what I remember and a royal PITA to change out...
I'm curious if the Dr. Rebuild diagram is actually labeled wrong...one of their selling points is that they do an actual circuit check (on a car) of all their wiring depictions..
Old Jun 30, 2013 | 01:43 AM
KNIPPS's Avatar
KNIPPS
Default Clip
Can this torpedo clip be bought?
Old Jun 30, 2013 | 01:57 AM
KNIPPS's Avatar
KNIPPS
Disregard. Found it from LI corvette.
Ps. Spoke to Lectric limited at bloomington and it does clip to the clock as some of you suggested. I guess the doc rebuild schematic was wrong. Thanks for the replies. Jim
Old Jun 30, 2013 | 09:00 PM
JohnZ's Avatar
JohnZ
Actually, it clips to the slot at 6 o'clock in the clock housing that rivets to the dash panel, and the upturned end of the clip rubs against the clock case itself to provide the ground for the bulb.
Old Oct 1, 2013 | 05:09 PM
stafftech's Avatar
stafftech
Would you mind telling which program you are using to tag your wires in the pictures you supplied?
Old Oct 1, 2013 | 06:43 PM
62Jeff's Avatar
62Jeff
DZVette is the originator of that diagram. He probably used MS Paint or something similar.
To Another wiring ??
