So, somehow a nut has been threw my motor and knocked a hole in my head, and if your wondering what happens it makes you have a river flowing out the side exhaust lol.
Anyway long story short, What heads are everyone running that are after market, Its on a 67 327.
90 over or so, its had a hard life
13.5 pistons,
duntov cam
team g high rise intake,
lunati ultra light crank,
bla bla bla,
Until I saw the "CF 10-year member" flag below his username, I was going to tell him to get off his mommy's computer and go back outside and play in the dirt.
C1 of Year Finalist (appearance mods) 2019
Most of the specs you seem to give are guesses and probably inaccurate, especially the 13.5 to 1 !!!
If you buy aluminum heads get the biggest chamber size you can to bring it down a touch....av gas is expensive.
its just a beater,
motor has been done years, probably 10 to 13. then i broke the crank, put new crank in and thicker head gasket so pistons would clear. the block has been decked at some point.
I have no idea where the nut came from, at first i thought it was off the breather but its the wrong size.
Ill look back threw the paper work and get the correct specs,
Your rod may be bent also....
I had a similar issue years ago, valve float popped the head off an intake valve, piston sent it through the head, but not before hammering the piston and rod into paperweights.
The forged piston was beat so much it was turned into a wedge you couldnt get the rings out..and the rod was s shaped.
Throw some AFRs on it would pick up BIG time.
Dont need a ton of lift to pick up power with a good head it will still breather more everywhere when that valve lifts off the seat
