I recently bought a 65 with KMC casting marks on the inside. They look like knock offs but I am suspicious and think they might be "bolt on knock offs". I searched KMC's web site but it looks like they don't make C2 wheels anymore. Does anyone have experience with these wheels?
From: Livin' large and havin' fun in wonderful Oklahoma
Can't be both......bolt-on or knock-off. Each are distinctly different. Most likely a knock-off made by KMC. From my experiences a quality wheel.
"bolt-on knock-offs" is a commonly used term to describe a wheel that looks like an original knock-off, but is bolted on instead while using an original-styled spinner for appearance.
It's also used to describe factory 67 bolt-on aluminum wheels, although at that point I think bolt-in knock-off is a misnomer because the 67 wheels made no attempt to represent themselves as a knock-off installation.
Somebody post for LoveMyC2 how a KMC bolt-on "spinner" hub cover comes off so he can try that first. Pics? I'd like to know how they're attached myself!
Pop out the center cap. There's a pin holding the spinner so it doesn't move. Take out the pin and spin the spinner off. Then the cone comes off, exposing the lug nuts.
Thanks, Vette Daddy! So the wheel has a protruding threaded center for the spinner to attach that clears the hub dust cap?
Go to one of the big Corvette parts suppliers and look at the pictures of wheels. You should be able to see the difference in a bolt-on verese a KO.
I you do indeed have KOs PLEASE do a search on how to properly mount these wheels. If done properly they will work like a dream, if done wrong the will work like a nightmare.
