1960 Grab bar / Dash insert help
I'm making progress with my new old gal. I installed the seat belts readjusted the glove box so it will stay shut and have moved on to the grab bar.
Bubba has been here for sure on this one. I was able to remove the grab bar and the brackets are in place and not loose thank goodness. However, I'm not sure how to get the insert out? It looks like bubba tried to slide that insert back but was unable to and just left it looking like crap and hacked it up in the grab bar area. I'm just wanting to make sure I'm not missing a step because it feels stuck and I don't want to start ripping and tearing for concern of my dash pad. Is it possible someone would have glued this piece in? Should there be anything behind the insert besides the dash pad? I'm hoping worst case is I just have to sacrifice the insert and get a new one. Just looking for some advice.
You have to remove the brackets
Not sure what you mean, but the insert assembly is bolted to the dash, through the dash pad, with studs that penetrate the fiberglass dash assembly. There are 3 nuts on 3 studs to be removed, once you get the brackets out of the way.
When people install new dash pads, they have to remove a lot of the foam from behind the insert, so that the insert will push deeply enough into the dash to allow that middle stud to penetrate. When I did mine, I had to push the insert really had and just barely got a nut on that stud. Then I tightened the nut to pull the insert further in place which allowed me to start the other nuts.
It looks like whomever installed that dash pad did not even cut a slot in the pad for behind the insert, and now the insert is just hanging out in the wrong spot.
So I understand why it is the way it is. So in theory I should be able to push it on through and atleast make it look 1/2 way decent until I want to remove and restore/replace.
1) Try pushing it, see what happens. Push on the top/bottom only, as the stainless steel strips are attached to the metal framework that contains the aluminum insert
2) If that doesn't work, you'll have to remove the brackets and pull the insert out so that you can trim away dash padding before trying again.
Platinum Supporting Vendor
