Fire!!!!
Old Oct 3, 2013 | 07:25 PM
Marks69BB's Avatar
Marks69BB
Default Fire!!!!
I was heading out today after work in my 60 to take in a local cruise-in and smelled, then saw black smoke coming out of the hood at a stop light. It caught fire less than a mile from my garage! Thank God I had a fire extinguisher with me and was able to put it out. it is a 2x4 car and the fire was in the front carb and was coming out of the louvers of the air cleaner. Had to get the friggin air cleaner off to put it out. Anyone have any clues what would cause the front carb to catch fire?
Everyone should have a fire extinguisher at all times with these cars!!!
Luckily I was able to catch it before it ruined the paint on the hood so it is contained in the engine bay but white sh-t is everywhere...
Pics to follow after my pulse settles down!
Old Oct 3, 2013 | 07:32 PM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
Marks69BB,
Good for you you were prepared. That is a gut check for sure. Glad it turned out without much damage. "Cleanup in aisle eleven", hopefully.
Can't answer the cause of the carb going up in flames but I am curious of the type of extinguisher (content) you used to douse it.
Jim
In God We Trust!
Old Oct 3, 2013 | 07:35 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
I know the feeling, that stuff is a bear to get off of everything. I hve been contemplating getting a Halon or what ever it's called now. They are expensive, but at least it doesn't make a huge mess when all you need it for is a small fire.
1snake's Avatar
1snake
That white sh-t is what saved your car from burning to the ground. Be thankful. Unfortunately, the front carb. on a 2 X 4 set up gets very little use (for most of us) and therefore gets gummed up easily because the fuel evaporates leaving a sediment, then it's re-filled and evaporates again leaving more sediment. This goes on and on until problems, like yours arise. Almost every one I've rebuilt, and I've done plenty 2 X 4's, the secondary jets were completely plugged and wouldn't flow any fuel.
Get your carbs. rebuilt and put your foot into it more often.
Jim
Old Oct 3, 2013 | 07:41 PM
1snake's Avatar
1snake
Don't waste your money on a Halon/Halguard/Halatron etc. extinguisher. True, they don't make a mess BUT, they also don't effectively put out flammable liquid fires. Without getting into the specifics of why, I'll only say that in the 30+ years as a professional firefighter and responding to 100's of car fires as well as teaching fire ext. classes to the public, I know what I'm talking about.
The O.P. used the correct ext. and saved his car. Enough said.
Jim
Old Oct 3, 2013 | 07:50 PM
sixtysixtom's Avatar
sixtysixtom
I use a product from RDR technologies called Cold Fire. Comes in an aerosol can and can be stored in your glove box. Supposed to be effective on all kinds of fires. Knock on wood I haven't had to try it out yet. It was recommended by another forum member at one time. Glad to here you saved the car and no pricey damage occurred.
Tom
myronf's Avatar
myronf
what kind do you have. mine is an abc ? maybe ab3c? not sure.
Myron
Old Oct 3, 2013 | 08:07 PM
Marks69BB's Avatar
Marks69BB
Default Pics
Here are some pics now that it is back in the garage:
Front carb driver's side
Passenger side
Outside
Before after rebuilt by Bob Kunz:
Fire extinguisher was Kidde Dry Chemical 10-B:C
Old Oct 3, 2013 | 08:08 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I had an identical fire on my dual quad '61. I cut it off in the garage and sort of a weird backfire more of a "phut" than a "pop". Decided to go raise the hood for a check and flames shot up a foot and a half. A fuel leak at the front of the front carb combined with a backfire did the deed. As with you, a fire extinguisher was a life saver.
I used my garage powder extinguisher and the stuff got everywhere. Fuel was leaking out the big nut on top of the carb near the red circle on my supposedly "professionally" rebuilt carb. The nut was barely finger tight.
Looks like you have a lot of sooty residue in the same area. Worth checking out.
Old Oct 3, 2013 | 08:14 PM
magicv8's Avatar
magicv8
I use an AFFF (Aqueous Foam) extinguisher like the airports use. Water based to limit damage.
Old Oct 3, 2013 | 08:25 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
You've got to use all of those eight barrels on a regular basis to prevent the gas sitting and gumming up the needle valves and seats. When they stick, you gotta problem. Welcome to the crappy gas era.
1snake's Avatar
1snake
That's the best of all of them. I have one in each of my garages but none in my cars. Those all have 20BC extinguishers. I spent 20 years as the officer on a Class A & B (AFFF) pumper and we were dispatched to all flammable liquid incidents. Nothing like pulling up on a fully involved 10,000 gallon gasoline tanker to get your heart pumping. Those are the days I miss most since retirement.
Old Oct 3, 2013 | 08:43 PM
Marks69BB's Avatar
Marks69BB
I was doing about 35mph and had a similar pop when I downshifted coming up to a stoplight and then the engine cut off. That's when I smelled then saw the black smoke.
Aside from the machanical issue being solved, how did you get yours looking new again?
Old Oct 3, 2013 | 08:48 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Anther good reason to have a extinguisher in the car and to use factory steel fuel lines If you had a bubbed rubber hose with a plastic filter it could be worse
Old Oct 3, 2013 | 08:50 PM
Frankie the Fink
Army
Mine weren't as bad as yours but I'm betting good carb cleaner would do it.
Old Oct 3, 2013 | 09:09 PM
rick1542's Avatar
rick1542
Veteran: Marine Corps
I am looking for the best fire extinguisher and am leaning towards the AFFF type and I know that if my 63 ever catches fire I am not going to worry about the paint/finish on the fenders but is there an extinguisher that is safe for the paint/finish? I would love to put the fire out and hate to repaint the car.
Old Oct 3, 2013 | 09:18 PM
69z28&ss396's Avatar
69z28&ss396
I LIT.. yes LIT my Z/28 on fire about five years ago. I had just moved to florida from japan, and had finally gotten the car down there from SC. I checked all the fluids from sitting for two years, fresh gas and I was really excited about a local cruise in at the bar a 1/4 mile from my house. At the show I noticed a drip under my car, (dark and it lit up from the ambient light) but I decided to drive home anyway. I proceed and get to my house and by that time a STRONG odor of gasoline was emanating from the vents in the car. I popped the hood and the light in the garage was dim, so like an idiot took the lighter out of my pocket to "see." The second I hit the wheel on the bic, a fireball raised out and singed my hair and eyebrows. My girl at the time, grabbed the fire extinguisher I had in passenger tunnel, without me saying anything and threw it to me. Total time from first light to out was prolly four seconds. Seemed like an eternity.. Powder everywhere, but cleaned up fine. Yes I know not to do that anymore, but it taught me one HELL of a lesson!! Nowhere man nailed it.. Rotten hose and plastic fuel filter.. Its all metal lines there now.....
To Fire!!!!
Old Oct 3, 2013 | 09:26 PM
Marks69BB's Avatar
Marks69BB
Jim
Yeah. Carbs have been on the car for a few years. I think part of my problem is I had thought this engine was slack and hadn't had a chance to address it due to other cars and stuff I was working on. Finally had an engine guy check compression in the cylinders which was fine but he found that it didn't have any advance so that explained why it was a pig. Fixed that and she grabs 2nd and 3rd with ease. Enjoyed the new feel twice and now this so maybe the build-up caused the fire.
Old Oct 3, 2013 | 09:31 PM
SpartyGW's Avatar
SpartyGW
Hey, 1snake, I don't doubt your expertise - I have ZERO. I want to educate myself on why Halon is not effective. I bought an expensive halon extinguisher because that's what they use in aircraft and automotive racing.
I suspect the primary reason for FAA use and auto racing is that it can be used in confined spaces without eliminating vision.
All I know is what I googled when I was shopping around. Can you elaborate more?
Old Oct 3, 2013 | 09:56 PM
C-1 Generation 2's Avatar
C-1 Generation 2
I just recently bought one too although I already had two dry chemical type. Just for safety sake would like to know the difference?
