Suspension bushing kit
The next step is to replace the suspension bushings and whatever else may be required for the suspension. The car is completely stock and I don't see where any parts of the suspension has ever been replaced (my grandfather and father were meticulous about keeping receipts, so I can see virtually everything that has been done to the car). Considering the bushings are 46 years old, I figure it's time for them to get replaced.
I looked on Amazon for bushing kits, but they seem to range all over the map. Can someone help me with what I will need to start with? I don't mind using polyurethane instead of plain rubber or anything like that (in fact I probably prefer it).
Oh yes, it's manual, not power steering in case that matters.
Thanks!
I would get the MOOG ball joints ( upper and lower), tie-rod ends ( inner and outer) and idler arm from AMAZON. I just had a customer who did this and it saved him a bunch of $$$$. Check prices and see.
As for the upper and lower control arm bushings...you have 3 options. 1.) Stock rubber. 2.) Polyurethane and 3.) Delrin bushings with grease fittings from Global West.
They go as numbered...number 1 is the easiest (but still a pain)...2 a bit harder...and 3 is for the advanced guy ...that one is for sure.
You HAVE to make sure that if you are dong it...or having someone install these bushings that if a press is being used to install them...that you have the tools that keep the lower control arms from getting collapsed and damaged due to their design. I have also made the same similar tool for the uppers when I do them.
You can get heavy duty sleeves for the tie rods from Vette Brakes and Products if you care to....or use the tubes and clamps like you more than likely have now.
As for using urethane...if you apply the correct grease during assembly...and tighten the bolts for the control arm bushings when the car is at correct ride height...I have some that are 20+ years old and are not needing service or replacement. But I know some people have had problems...and I am sorry to rear that...but I have not to date.
Now for the rear strut rods...I do have to agree that the urethane bushing can fail...but then again...so do the rubber ones. Which is why if the customer can afford it and wants them...I prefer to use the spherical end strut rods with grease fittings.
DUB
I put polygraphite bushings in my '90 Suburban. They only squeaked going over speed bumps, and lasted a couple hundred thousand miles.
