The VIN #19467S122685 - would seem to imply a chevy, corvette, convertible, 1966, built in St. Louis and the Production #122685 would appear to show a late April production month.
But I see this same VIN list for 1965 corvettes with a different build date.
The Block number is 3782870 and this shows up as a 1965 date. I believed I had a 327/350 but this number shows a 327/250. There is also another number on the right side of the motor - 4931752.
Check the numbers on the passenger side front pad of block ( look at the ledge below the front of the valve cover. You will see one set of numbers which will be your VIN and another which will denote the engine and date. Look at those two sets of characters and post them.
BTW, that first 1 is just a holding character so your 66 is really number 22,685.
The only number on that flat plate is 4931752. Now that adds to the mystery.
It looks like I have a 1965 327/350 block and 1966 top half.
1. Front pad (engine ID stamped) number - 4931752
2. Rear casting (raised) number - 3782870 --- this is a 1965 number
3. Heads number - 3782461 --- this is a 1966 number
4. Carb, Dist, Alt, Reg, Expansion, Starter, Coil are all 1966 numbers
5. The VIN on the plated under the glove compartment is -- 19467S122684 This being the production number and is 1966. And does not match engine ID number.
Would you all agree I have a '65 block with everything else being '66? I'm not showing this car so does it really matter? I'd just like to know where the block came from.
I agree you may have 65 case, or 64, 63 or 62. Does it really matter how? Does your vette look good and run well? If so, I don't see how anything you have noted here matters.
Yes, it's a pre-'66 block. That block was in production from '62 through '65 - what's the block casting date (about 4" to the right of the distributor on the rear flange of the block, opposite the casting number)?
uu
I checked the Casting Date and is shows H274. That would be August 2, 1964. That solves some questions.
The bad news just gets worse. Thought I had a '65 engine because of the Casting Number but it was used in 64 also and the DOB is a fact. Looks like I have a '64 block with '66 top end.
Question 1. Is August 2, 1964 a late production date?
Question 2. I know it is a 327 CI motor but how do I know the HP?
H274 would be August 27th, 1964, not August 2nd. The block originally was installed in a 1965 Chevrolet (but not necessarily a Corvette), as all 64 production had ceased by the end of August.
Without an engine suffix code, stamped in the pad, there's no way of knowing what the block started out life as, and/or what it was installed in.
