Need a little help from the experts I have a 66 roadster with 327 4 speed with engine code HR all numbers match vin on the car but everything I look up says an HR code is with powerglide this appears to always have been a 4 speed , no sign of any cooler line fitting in radiator or linkage changes etc. Any ideas would be greatly appreciated , Thanks
HR is base engine, powerglide, with California K-19 A.I.R. smog system. There is no "cooler line" fitting in the radiator for p/glide, as all small blocks used the same radiator. The p/glide cars had a separate small Harrison air-air heat exchanger in front of the radiator that circulated hydraulic fluid from the trans through this unit. Pic of my 'HR' '66 engine pad below.
OK yes I forgot about the external cooler, but if that's the case someone went to great lengths to hide the fact it was ever a p.g. never have looked under a powerglide 66 but is the x member and exhaust mount and all that the , boy this thing sure looks like it was a 4 speed from day one , I guess its possible is there anny telltale thing I could look for?
If the front block stamp pad looks typical, including the VIN derivative stamp, it was born a Powerglide K-19 and has been converted to a 4-speed at some point. If it was a Powerglide to start with, there will be two Rivnuts in the front side of the lower crossbar of the radiator support where the Powerglide trans fluid cooler was mounted. Got a good close-up hi-res photo of the stamp pad?
Your trim tag won't tell us anything, as you have a black interior, so the body-affecting options aren't coded.
Thanks John Ill check that and get a photo of the ID pad Thanks
That's my HR block, John, not that of the original poster. I attached the picture for mddawg to compare to his engine.
here is the stamp number and it does have the rivnuts so I guess somebody swaped in a 4 speed
I’m surprised no one suggested looking at the Muncie numbers. A ’66 should have a 3885010 main case, which would be easy to obtain but also check the serial/date stamp (P….) and see if it has a VIN derivative stamp. It’s possible to get a date correct Muncie but the VIN stamp is probably not correct or missing. This is probably the second biggest tell-tale sign after the engine pad.
Other tell-tale signs would be the routing of the speedo cable. A powerglide cable routes on the left side would have come with a cable clip on the left side of tunnel and no clip on the right side – see if one has been added on the right and how it was attached? The 4-speed cable routes on the right side and enters the firewall at a different location. Look at your AIM to see the differences in location and firewall plugs.
Good info thanks , Ill check those things out, I guess fortunately its a friends car and I'm just doing the work ,he's had it since 86 but hasn't been driven since 91, he bought it used so hard telling what happened , not doing a concours restoration more of a driver but replacing and rebuilding everything. Thanks
