Timing Marks Description
Old Jun 12, 2014 | 11:43 PM
  #41
BigT-65's Avatar
BigT-65
I don't have a dial back timing light. I think I will get a total advance timing done when I bring it to the shop for the oil leak and some other issues I need fixed.
Old Jun 13, 2014 | 06:16 PM
  #42
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
You can set total by making a mark on the damper. Measure it's circumference, divide the result by 10, and put a mark that distance from 0º. That will be 36º. To set total at something other than 36º align that mark with +2, -2, etc.. Be sure that it's through advancing before setting total. Depending on the particular distributor, that may not be until 4-5K.
Old Jun 13, 2014 | 11:34 PM
  #43
BigT-65's Avatar
BigT-65
Now, this sounds like something I can do. Thanks, but I need a little more detail though. "Make a mark on the damper" where and when and what would be the other mark? 0?
Old Jun 14, 2014 | 12:18 PM
  #44
Vetterodder
Yes. With the 0 mark at the top, the 36º mark would be towards the drivers side. Once you're calculated the correct distance, mark a piece of masking tape with 2 marks that distance apart. Put the tape on the damper with one mark aligned with zero. Use a light colored paint or marker (I usually use touch-up paint) and put a mark on the damper at 36º, remove tape and you're done.
Old Jun 14, 2014 | 07:43 PM
  #45
JohnZ's Avatar
JohnZ
Read these two articles, especially the second one:
http://www.lbfun.com/warehouse/tech_...101Article.pdf
http://www.lbfun.com/warehouse/tech_...%20ADVANCE.pdf
