Timing Marks Description
Old May 6, 2014 | 11:53 PM
BigT-65's Avatar
BigT-65
Default Timing Marks Description
I am not a mechanic so don't laugh. I always though the timing marks on my 65 327 were After 0 Before but now I know it's Advance 0 Retard. The R always looked like a B to me. Anyway I am assuming that A is Before TDC. Correct?
Old May 7, 2014 | 12:32 AM
ghostrider20's Avatar
ghostrider20
Yes. And every line on the timing tab is 2*.
Old May 7, 2014 | 11:47 AM
BigT-65's Avatar
BigT-65
Thanks for the reply. I didn't know each mark was 2. My engine seems to be timed correctly but I have the timing set 8 marks up. That would be 16 deg.BTDC. What do you think about that?
Old May 7, 2014 | 01:34 PM
JohnZ's Avatar
JohnZ
That's excessive. What engine do you have, and what distributor?
Old May 7, 2014 | 01:54 PM
BigT-65's Avatar
BigT-65
it's a 327 300hp timing is suppose to be 8 deg BTDC. If I move it down to 4 notches it runs really bad.
Old May 7, 2014 | 03:15 PM
JohnZ's Avatar
JohnZ
Have you verified that your vacuum advance is working and is connected to a full manifold vacuum source? Most 327/300's are very sensitive to base timing, and are only happy at 6*-8* BTDC (set with vacuum advance disconnected and plugged). With a functioning vacuum advance, you should have about 21*-23* BTDC at idle.
Old May 7, 2014 | 03:32 PM
ghostrider20
Have you ever confirmed Top Dead Center (TDC) on the #1 piston and confirmed the timing line on the balancer is lined up with the zero mark on the timing tab?
What RPM are you idling at when checking timing? Also, as JohnZ pointed out you have to set your initial timing with he vacuum advanvce hose disconnected.
Old May 7, 2014 | 06:55 PM
DUB's Avatar
DUB
100%. I deal with so many balancers that have the outer ring with the notch spun and not in the correct position so when using a timing light...it proves to be ineffective. I have to check a few every year.
What RPM are you idling at when checking timing? Also, as JohnZ pointed out you have to set your initial timing with the vacuum advance hose disconnected.
DUB
Old May 7, 2014 | 07:45 PM
BigT-65's Avatar
BigT-65
Ok, here is some more info. The distributor is 1111024. It has Pertronix Igniter II installed. The number one spark plug is connected to the distributor on the post just to the right of the dwell window. I have never confirmed that the TDC is on the #1 piston and confirmed the timing line on the balancer is lined up with the zero mark on the timing tab? Something I should check. When I set the timing I did have the vacumm advance disconnected and a vacumm gauge hooked to the port on the carb. The vacumm advance does appear to be working because when I connect it the timing jumps up several degrees. While adjusting the timing I have the engine idling at 800 rpm.
Old May 7, 2014 | 09:31 PM
ghostrider20
- Perfect
- Yes. You could verify the correct balancer by part number, size, etc. I don’t know much about the variations in designs over the years, but I recall there is a difference. Same goes for timing covers WRT the timing tab, and also after-market
bolt on timing tabs. If you are 100% confident that yours are correct, then don’t bother with it. But if there is any doubt, then confirm with the TDC alignment test. I use a USB dental scope (poor mans borescope) hooked to my laptop to watch the piston. Just be sure to get it on the compression stroke!
- Perfect. By chance do you remember your vacuum reading?
- How many degrees? Are you using a dial back timing light ?
- Try idling it down to the 500 RPM range, just for the purpose of setting the initial timing. I am not familiar with the specs on the 300 HP distributor, and at what RPM the mechanical (centrifugal) advance begins to deploy, but you may be getting a few degrees of centrifugal advance at idle. Not a huge problem but you want to know where the base timing is at. I think you are looking for 8* BTDC or what ever JohnZ suggested.
Get the initial timing confirmed and set then lock the distributor hold down bolt. The rest of the timing tuning will not require you move the distributor base.
Old May 7, 2014 | 10:08 PM
BigT-65's Avatar
BigT-65
Ghostrider, You have a nice car there. My car is a 65. I think it has a 64 engine. The block had been shaved at some time in the past and most of the numbers on the pad are not readable. I have had the car for 30 years and it has always been set on the 8th mark on the tab. Other than some carburetor problems I have been having it has been running good. I do want to check that alignment again. It seems like I had done it many years ago but I am not sure.
Did they make any timing tabs that had gradients of 1 degree?
The vacuum reading was right on 20 I don't have a dial back timing light. The timing mark on the balancer moves up about an inch and a half maybe a little more. The reason I was idling at 800 is because the car is an automatic. When I put it in gear it drops down to 500. For the purpose of setting the timing I could lower it to 500 but it needs to be higher in service.
Old May 7, 2014 | 11:03 PM
ghostrider20
- Thank You.
- The balancer should have a part number on it somewhere. It may not be legible with it installed.
- Maybe an aftermarket tab??
- I am not sure. As far as stock GM stuff I have only heard of 2* per line on the tab WRT to classic corvettes.
Yes, just for setting the timing, idle it down low just to verify the fly weights in the dist. are not adding any advance. Turn it back up to what ever you like when you confirm and set the base timing.
Old May 7, 2014 | 11:13 PM
BigT-65's Avatar
BigT-65
What would be the procedure for checking the TDC alignment without using high tech equipment? I am going to look into some of these suggestions this weekend.
Old May 8, 2014 | 10:44 AM
ghostrider20
A "piston stop" or "piston locating tool". If you have never used one, follow the instructions, and do all movements of the engine by hand.
You can most likely rent one from some of the box chain parts stores.
Here is one on ebay.
http://www.ebay.com/itm/Big-End-Performance-Top-Dead-center-locator-tool-14mm-piston-stop-/370970330074?hash=item565f8e03da&item=370970330074&pt=Motors_Automotive_Tools&vxp=mtr#ht_165wt_662
Try and find a dial back timing light as well. Will make the whole job alot easier.
- Mark
Old May 8, 2014 | 10:53 AM
ghostrider20
Here is a similar borescope to what I have. For the few dollars more then a locating tool ! I used it to snake into my intake to look at valves and gaskets just recently.
http://www.ebay.com/itm/USB-Endoscope-Borescope-Inspection-waterproof-Camera-w-Flexible-Supporting-Tube-/321395006661?pt=LH_DefaultDomain_0&hash=item4ad4a29cc5#ht_4649wt_873
Old May 8, 2014 | 05:26 PM
DUB's Avatar
DUB
I use a home made tool that looks just like what is pictured in post #14. I made mine out of an old spark plug and tapped it so i could thread a long bolt just like what is pictured.
I also have a flywheel turning tool which makes it quite easy to find TDC for cylinder 1.
DUB
Old May 8, 2014 | 10:18 PM
BigT-65's Avatar
BigT-65
I saw someone make one of those on YouTube. I also saw some on ebay for $9.00 and free shipping. This is my question about those devises. They look like they are adjustable. How do you know how long to set it at and if you made your own how would you know how long to make it?
To Timing Marks Description
Old May 9, 2014 | 12:53 AM
steampunk c1's Avatar
steampunk c1
Simple test gauge can be made from old spark plug brack up the porcorlen and hot glue a plastic tube into the plug insert it into no 1 on power stroke (both valves closed) as you turn the crank to tdc use soapy water to make a bubble on end of the tube large bubble = tdc.
Old May 9, 2014 | 09:58 AM
BigT-65's Avatar
BigT-65
Sounds like a good idea. I am going to see if I have an old spark plug laying around and give it a try. If I have to set my timing at 16 deg BTDC (8 marks on the tab) my harmonic balancer must be shifted and I need to verify that. I also am going to order the tester on ebay today.
Old May 9, 2014 | 03:11 PM
tbarb's Avatar
tbarb
I don't know if it's been mentioned but you could have the later 1969 and up timing cover. There is approx. a 10* difference if you have the later cover with a early engine damper.
Also, be very careful turning the engine with the spark plug/bolt piston stop.
