brake lights
Old May 18, 2014 | 12:34 PM
nicko64's Avatar
nicko64
5th Gear
Default brake lights
how can I temporally bi-pass the turn signal switch to wire my brake lights?
Old May 18, 2014 | 02:24 PM
65GGvert's Avatar
65GGvert
You'll have to connect the white wire coming off the brake light switch and going up to the turn signal switch to both the yellow and the dark green coming off the turn signal switch. If you're going to all that trouble, you'd be better off just to fix the turn signal switch. If you want to do it, connect the white, yellow, and dk green wires together where they come down the column from the turn signal switch. That's what the turn signal switch does internally when the turn signal is in the center position.
