Headlight Problems....
Old May 30, 2014 | 03:21 PM
maxpower_454's Avatar
maxpower_454
Default Headlight Problems....
Hi, I just had both headlight motors rebuilt for my 67 but the passenger side light is still slower and then stops sometimes. Sometimes it stops mid stroke, sometimes it rolls all the way but then won't move again. When it stops, I wait a little and then it will move again. Any ideas what could be wrong?
Old May 30, 2014 | 03:37 PM
JohnZ's Avatar
JohnZ
While you had the motors out for rebuild, did you check both buckets for free movement through their entire range of motion? If your shaft bearings are corroded or seized to the pivot shafts, the motors won't operate them properly.
Old May 30, 2014 | 10:10 PM
maxpower_454
Yes, I checked. Both buckets operate freely. It almost seems like the power is cutting out for some reason.
Old May 30, 2014 | 10:17 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
I had a somewhat similar problem with one of my headlights. Resolved it with a little WD40 type lubricant on the pivot shafts.
Old May 30, 2014 | 10:18 PM
rwerth7's Avatar
rwerth7
Check for 12 volts and ground at the motor when that motor stops or will not start.
Old May 31, 2014 | 11:34 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Probably don't want to hear this but the Detroit Speed electric conversion kit is the only way to go. It eliminates the rotational switch and the buckets spin around quickly and in perfect unison.
Not "original" but no one will know but you and they work awesome.
Old May 31, 2014 | 11:40 AM
Rokndad's Avatar
Rokndad
+1. Rebuilt my original motors and stored them away. The Detroit Speed conversion is the only way to go if you're not worried about Top Flight/Duntov judging. Very convenient and dependable.
Tom
Old May 31, 2014 | 12:18 PM
wombvette's Avatar
wombvette
If the motor is struggling or is in a bind, the internal limit switch will turn power to the motor off. That is why the motor works again after a rest. The switch cools down and reconnects.
Old May 31, 2014 | 07:43 PM
maxpower_454
That makes sense. I will take it back apart and see if I can make the bucket spin smoother. I will check back with results. Thanks all
Old Jun 7, 2014 | 10:25 PM
maxpower_454
Well I lubed up that bucket and it rotates as free as possible now. Motor still cuts out now and then. Anything else I should try?
Old Jul 24, 2014 | 10:03 PM
Robert Lewis's Avatar
Robert Lewis
If you're still struggling with this I'd recommend disassembling the gearboxes one more time. It's crucial to get all the old grease out before you repack with wheel bearing grease. Then run the motors on the bench and make sure they're moving energetically before you attach the gearboxes.
Let me know if you need more specific help and I'll walk you through it.
To Headlight Problems....
