Valve adjustment Different question
Old Jun 12, 2014 | 02:35 PM
MikeM's Avatar
MikeM
Run the engine longer than four minutes. Couple of days.
Old Jun 12, 2014 | 02:38 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
At least - it won't hurt a thing. After a few days the tick should go away if it was indeed a gummed up lifter. If not its a mechanical issue.
Old Jun 12, 2014 | 02:48 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
, or till the next oil change....
Bill
Old Jun 12, 2014 | 09:25 PM
rick1542's Avatar
rick1542
Veteran: Marine Corps
It ran for about 45 min. for the first 4 min the tick was gone but returned. I will run it until its next oil change
Old Jun 12, 2014 | 09:52 PM
67*427's Avatar
67*427
How much MMO did you add? I wouldn't be afraid of 16-32 oz.
Old Jun 13, 2014 | 07:39 AM
rick1542's Avatar
rick1542
I took a quart of oil out and put a quart of MMO in. I'm not convinced its a gummy lifter (only because of my level of luck) I think it's something more. But if it were a bad lifter, cam or spring wouldn't that affect the performance of the engine?
Old Jun 13, 2014 | 07:49 AM
Frankie the Fink
Army
Not necessarily, I had a 327ci Camaro that had a tick in it for 6 months and I drove it daily until I could pull the intake and fix it. The only symptom was the annoying tick.
Do not discount the prior advice here that it might be an exhaust leak.
If it is definitely a lifter its not that big a deal to pull the intake and replace it.
Old Jun 13, 2014 | 09:27 AM
tbarb's Avatar
tbarb
A wiped cam could present itself as a noisy lifter before the engine looses a cylinder. Also, a rocker stud could back out presenting itself like that but from you description I would look at the exhaust manifold to head interface for a leak.
Keep with the simple stuff first.
Old Jun 13, 2014 | 09:45 AM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Originally Posted by tbarb
A wiped cam could present itself as a noisy lifter...but from you description I would look at the exhaust manifold to head interface for a leak.
With a small block Chevy, the simple stuff is always more likely to be the problem. Check for an exhaust leak with a cold engine, use the back of your hand as close to the manifolds as you can comfortably get to feel for the tell tail hot breeze. Exhaust ticks sound remarkably like a lifter tick.
A wiped cam lobe would not, to my way of thinking, go away with Marvel mystery oil & then come back. A bad lobe might tick & fade with rising engine temp and/or be masked by all the other noise but would eventually return louder and louder until the lack of valve movement presented itself as a performance issue.
Dan
Old Jun 13, 2014 | 12:54 PM
rick1542's Avatar
rick1542
Its my understanding that SBC (1963) came from the factory with no exhaust manifold to head gaskets. That's the way mine was done, w/o a gasket.
Old Jun 13, 2014 | 01:09 PM
JohnZ's Avatar
JohnZ
ALL Chevy V-8's through the mid-70's used no exhaust manifold gaskets - they were all metal-to-metal.
Old Jun 13, 2014 | 01:48 PM
rick1542's Avatar
rick1542
So I guess that could increase the likelihood that my issue is an exhaust leak. Other than stating a cold engine and feeling around the manifold for a leak is there another way to check?
Old Jun 13, 2014 | 01:59 PM
  #33
JohnZ's Avatar
JohnZ
If you have a mechanic's stethoscope, you can do that check very quickly and accurately.
Old Jun 13, 2014 | 03:27 PM
  #34
tbarb's Avatar
tbarb
This gasket area was discussed on the NCRS discussion board some time ago and a poster recommended using a gasket sealer that withstands high temperature but I can't recall the brand, maybe someone here will remember.
Old Jun 13, 2014 | 06:02 PM
  #35
Frankie the Fink
Army
Should be one in every mechanic's tool box...or at least a 4 foot length of rubber garden hose (it can do the same job).
Old Jun 13, 2014 | 06:22 PM
  #36
rick1542's Avatar
rick1542
I went out and got one. Also I tightened up the exhaust manifold. When the engine is cold and until it get hot the tick is not there, when it reaches opp temp you can hear it, clearly
Old Jun 13, 2014 | 06:28 PM
  #37
MikeM's Avatar
MikeM
If your stethescope confirms it IS and exhaust leak, get a set of gaskets for that side and tighten manifolds back to the head. Your problem could be solved that simply. Or you could do it the hard way, remove the manifold and have it surfaced.
The gaskets are easy. Just cut a 3/8" slot in the bottom, loosen the manifold and drop the gaskets in. No need to completely remove them.
To Valve adjustment Different question
Old Jun 13, 2014 | 06:32 PM
  #38
Frankie the Fink
Army
Hmmm...usually an exhaust leak goes away when things heat up and expand and seal up gaps but you can clearly hear it cold. I'd run the car a few more days with the MMO anyway and if the tick doesn't go away, or, you ABSOLUTELY confirm its an exhaust leak you can do as MikeM says. Its a 1/2 hour job and yes, you do not have to remove the manifolds.
If you're lucky you won't have those French locks to deal with.
Old Jun 13, 2014 | 06:50 PM
  #39
rick1542's Avatar
rick1542
What are French locks?
Old Jun 14, 2014 | 09:04 PM
  #40
JohnZ's Avatar
JohnZ
Those are the stamped sheet metal locks the last guy who worked on it threw away when he removed the exhaust manifold bolts. The front and rear pairs of bolts use them (but not the center two).
