FI heat barrier
St. Jude Donor '07
FI heat barrier
a friend sent a picture from an article in the recent NCRS Restorer about using a piece of Hardee Board as an insulator to shield the spider.
seems as it may have merit.... anyone seen the article?
opinions? (yeah, and not of the "everyone has one" kind. .)
Bill
Bill
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
I've seen these new of ebay for about $40 from a guy in FLA. I think he can even make them for later model FI units.....................
http://www.ebay.com/itm/58-59-60-61-62-CORVETTE-FUEL-INJECTION-PARTS-LOT-/131259299447?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1e8fa9f677&vxp=mtr
Brian Futo wrote that article. I have spoke with him before and he claims it works in AZ heat. That is where he rebuilds FI units. I currently put a piece of reflective heat barrier on my base plate under the spider and have noticed a difference.
If you try the technique in the article, let us FI guys know how it works. I would imagine the hardy board would absorb heat well.
St. Jude Donor '07
2nd thought.... i THINK the hardee board would be too thick and would stick up above the gasket surface the one piece gasket has to fit.
3rd thought... the reflective heat barrier (if it has an R-value) sounds like a good idea.
if Brian says it works, especially on a C1, in AZ; then it sounds to be worth trying. especially if a piece of the reflective material could be put on the bottom....
Bill
St. Jude Donor '07
Bill,
Bill
I would be wary about using Hardie Product esp where heat is involved. the stuff will turn into weetbix in short order.
I used to work at James Hardie here in New Zealand for 18 years designing their production machinery. They removed the asbestos from the product years ago, so it's heat resisting qualities are diminished greatly (as well as it's strength). They replaced the asbestos with craft pulp - essentially brown cardboard pulped and shredded.
Neville
St. Jude Donor '07
Hi Bill,
Neville
Neville
sure is fire resistant tho, but not sure if there is an R-value in that...
http://www.homeadvisor.com/article.s...ing.15726.html
Bill
wmf62, can you give me a volume and edition number for the Futo article. Or the year and season please.
Dan
Dan
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I can't help but be somewhat skeptical about the use of a heat barrier between the adapter plate and the plenum.
Once the engine and engine compartment is THOROUGHLY heated up, it would seem that the ENTIRE area in and around the area of the top of the engine would be the same temperature. It would seem that the temperature surrounding the engine would also work its way between the heat barrier and the underside of the plenum, until movement of the car and airflow from the fan begins to remove the hot air under the plenum. Once that occurs, everything works fine.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Jim
I have heard it postulated that the hot oil hits the underside of the adaptor and causes the adaptor to be hotter than the surrounding water temperature cooled components. This would lend some credibility to the need to put a thermal barrier between the adaptor and the spider. You could also put a heat shield on the underside of the adaptor to prevent the direct impingement of the oil unto the underside of the adaptor. Chevrolet did this with some of the HP intakes.
Received 1,843 Likes
I believe that heat shield was riveted to the underside of the manifold was to keep motor oil from cooking/caking on the bottom of the even hotter exhaust crossover passage.
Could be wrong though.
Received 1,857 Likes
You are correct - that's exactly what the shield is for; fortunately, the F.I. cars don't have to worry about it.
