1966 dash harness
Old Aug 11, 2014 | 12:23 PM
chrislyn's Avatar
chrislyn
Default 1966 dash harness. ADDITIONAL QUESTION !
I need a real good picture or pictures of the dash harness laid out on the ground as it would be installed in the car. I am missing a couple of plug ends and wires on the right side and center In need of pictures for a 1966 late dash harness. Thanks, Wes
ADDITIONAL QUESTION.
Thank you John and Jack both of you are spec on. I have one other request. Can or do you have pictures or other of the tranistorized harness where the wires connect to the distributor coil and the harness itself. I noticed on the new harness that there where pink wires with plug connections that where taped into the engine harness. Not sure what to use. Thanks again, Wes
Old Aug 11, 2014 | 12:53 PM
66jack's Avatar
66jack
http://forums.corvetteforum.com/c1-a...ng-photos.html
OR
This one from BlackMagic is probably better for searching...
http://www.stl-vettes.com/65Vette/co...Group=Electric
Old Aug 11, 2014 | 01:03 PM
JohnZ's Avatar
JohnZ
Here's the whole dash harness, group by group (Dave Zuberer).
File Type: pdf
Old Aug 11, 2014 | 01:28 PM
chrislyn's Avatar
chrislyn
Thank you John and Jack both of you are spec on. I have one other requests. Can or do you have pictures or other of the tranistorized harness where the wires connect to the distributor coil and the harness itself. I noticed on the new harness that there where pink wires with plug connections that where taped into the engine harness. Not sure what to use. Thanks again, Wes
Old Aug 12, 2014 | 11:50 AM
chrislyn's Avatar
chrislyn
Ttt
Old Aug 12, 2014 | 05:12 PM
DZVette's Avatar
DZVette
Ttt
Wes,
Not sure if these are the taped wires you are referring to but on my 65 harness (AC car with Powerglide) these two connectors came taped to the engine harness and they were for the neutral safety switch on the PG trans. The wires are lavender/purple.
Dave Z
Old Aug 13, 2014 | 02:57 PM
chrislyn's Avatar
chrislyn
Originally Posted by DZVette
Wes,
Dave Z
Dave thanks for responding. On my harness the plug that is on the harness is purple on both sides of the plugs. That is the Plug that I am questioning. My backup switch connection come off my dash harness ,come through the firewall and use a green and pink into a plug connection. I believe maybe your harness is a bit different.
Old Aug 13, 2014 | 08:00 PM
DZVette's Avatar
DZVette
Wes
Those wires are purple on my '65 too. Didn't mean to confuse you with that "lavender" bit above. These are the wires that connected to the plugs in the engine bay. You can see them and the back-up light wires in the photo of the shifter area below.
DZ
Old Aug 19, 2014 | 07:53 AM
chrislyn's Avatar
chrislyn
Wes
DZ
Do you think the engine harness would be the same through the 65-67 years as to make one for all.1965 using that purple plug connection and 66-67 using a different backup light connection cause mine as I had said came through the firewall using the plug off my dash harness and connecting to the switch So than on mine I would leave the purple wire plugs taped In the harness. Does that sound right. Thanks, Wes
Old Aug 19, 2014 | 08:54 AM
wombvette's Avatar
wombvette
They are all different to some extent, but they still use purple in color for the safety switch.
Old Aug 19, 2014 | 08:51 PM
vark_wso's Avatar
vark_wso
Wes
Back up lights were an extra cost option until '66 when they became standard equipment. Code T-86 for '63-'64 and Z-01 (comfort and convenience group) for '65. L/L may include this provision in their harnesses -- don't know if the general did.
Jeff
Old Aug 20, 2014 | 10:36 AM
chrislyn's Avatar
chrislyn
Originally Posted by vark_wso
Wes
Jeff
Thanks Jeff
To 1966 dash harness
