Speedometer Cable
Old Feb 8, 2015 | 08:21 AM
ByByeAmericanPie's Avatar
ByByeAmericanPie
Default Speedometer Cable
Now that the new Vette is here, you guys get ready for a flood of questions.... First one... does anyone have any detailed instructions on replacing the Speedo cable? I can hear it beneath the dash and the speedo operation is questionable (bounces a lot)...
Old Feb 8, 2015 | 08:24 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Again - you really need to state what car you're dealing with.
Old Feb 8, 2015 | 08:37 AM
Solid Axle Guy's Avatar
Solid Axle Guy
Looks like it might be a 61 Frankie.
If You can "hear" it & it bounces that is a telltale sign that it the inner cable needs to be lubricated with white lithium grease. Unscrew the one of the cable ends at either the tranny or speedo head. Pull the inner cable all the way out of the outer cable case. Check for defects. Clean. Lubricate liberally with white lithium grease. Reinstall & hopefully gleeful bliss.
Old Feb 8, 2015 | 08:43 AM
Frankie the Fink
Army
Prob is a '61....I use special purpose graphite lube Kable-Ez or something like that (forget the name). Sometimes pulling that inner cable out works; sometimes I've never gotten it to completely seat again - then things get interesting....
Old Feb 8, 2015 | 08:50 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Keep in mind it may just need grease or graphite.
Old Feb 8, 2015 | 05:02 PM
ByByeAmericanPie
Thanks guys! It is a 61, late production VIN 10012. I will try to lubricate it first.
Old Feb 8, 2015 | 05:36 PM
Fawndeuce's Avatar
Fawndeuce
Graphite is usually a better lubricant for Tach and spedo cables, won't gum up over time, and you don't want it working its way up into the spedo.
Paul
To Speedometer Cable
