I'm planning to install the motor back into my 55 in a few weeks and have a question about the best/safest lift points for this.
When I removed the motor without the trans I used the 4 outer intake manifold bolt locations. Now that I am putting it in with the trans attached, I am concerned about the best points to lift since I will be tilting the heavier engine/trans a lot more during the install. I don't want to damage the FI intake manifold that is already installed on the motor. I have a 4 chain leveler.
Should I use the 4 outer exhaust manifold bolts or am I OK with the intake manifold location? Or, should I use head bolts instead?
Additionally, I have read about shims being used on the RH frame engine mount. When I removed the engine mounts, there were no shims, so I assume I do not have to worry about this. What was the purpose of the shims at any rate? Thanks for your help.
Since I have a newer engine/heads, I always use the bolt holes on the front and back of the heads. Since you don't have those, I would be inclined to get longer chains and use the exhaust manifold mounting holes. It gives you a wider base for balancing/maneuvering the engine and trans around as you're dropping it back in.
Not to highjack your thread, but I have a question for the others here. I have seen engines hoisted by a plate that bolts to the carburetor mounting studs. I guess it works, but it just doesn't seem like those carb studs are really strong enough to handle the weight of an engine/trans.
I have used the same exact points on the intake as what you used and HAVE NEVER had an issue. I ALWAYS pull the engine with the transmission attached. I also have an engine tilter and would be lost without it. I have installed big blocks and small blocks , automatic and manual transmission and never had an issue.
My set-up allows me to correctly position and make sure the bolts I use in the outer intake manifold bolt areas will not hurt the intake and NOT BEND.
I have had the same concern of a carb lift plate, but searching the archives, there was a lot of good info, what I remember most was an aluminum manifold with a good tapped hole will with stand 500 lbs. so four studs would hold 2000 lbs, I have used a plate multiple times ...no issues
was
Recently, I pulled my engine twice. Both times I used a carb plate. From what I could tell it gave me more clearance then using the intake bolts. I did use the intake option when I first installed the engine. The only thing I would be concerned with is making sure the balance is good while you are lifting it up and over the front end body. Also installed the engine with the transmission. I never pulled it out with the transmission.
I still don't understand the engine mounting procedure as described in the assembly manual. Does anyone use shims and why? Seems that lowering the engine on the mounts should be straight forward. Since this is the first time I will be doing it, I would appreciate any tips and things to watch out for.
I will use grade 8 bolts for sure. When the rebuild shop lifted and transported the motor using the intake manifold points, one front bolt pulled out, slightly damaging the manifold! Fortunately it was repaired, but hence the reason for my concern.
I can COMPLETELY understand your concern. And TRUST ME....I make sure that when I am installing my bolts they are threading in as far as possible and yet NOT bottoming out. I also have Grade 8 Allen studs that I can thread into the head and then attach my washers and brackets, chain, etc. and get it how I need it. For me...on some engines....I can spend a bit of time getting the engine tilter set-up the way I NEED IT to be so I do not have a problem. The way I look at it. IF I spend an hour getting it right...that is still less time than what it will take to repair a problem.
