I need to pull and rebuild bro n laws water pump on the 59.The service guide says to jack from below so you can take the front engine support off.Do you think I could make something out of wood to spread the load on oil pan and jack it that way.I'm also putting a pic of the thermostat housing when I removed upper rad. hose.Thanks for any suggestions on the jacking.Eddie
Welcome to the CF. Hopefully you will do as suggested. Part of that calls for removing the plug on each side of the block that allows the remaining coolant to be drained. But, many times, and I sure in this case, when the plug is removed, the hole is clogged with crap. Use a pointed object to get it cleared and proceed too flush the entire cooling system including the heater core. A note about the core. Too remove the hoses, slice them and then peel them off. Don't wrangle the hoses, that may break the connection rendering the core useless. Hope this helps. Dennis
Here's an engine lifter I made nearly 20 years ago that picks up the engine on the pan rail and doesn't risk damage to the bottom of the oil pan. The base is a 2x6, 9-1/2" long, and the sides are 1x6, 8" high, attached with four 3-1/2" long wood screws up through the base on each side. The notch in the side is to clear the "bump" in the pan for the dipstick. Crude, but very effective.
I have had to replace the water pump on my 59 several times over the 53 years I have owned her.... absolutely no problem in using a piece of wood on the oil plan to lift the engine....remember, all you have to do is take the weigh off the engine mounts....raising the engine 1/4" should be more than enough...
I built the same thing as JohnZ as I would rather have the weight on
the flange of the pan then the bottom. I also found that using studs to align the gaskets, mount and pump made it simple to assemble.
I just bought exhaust manifold studs at an auto parts store.
Larry
John, that is a thing of beauty. And a lot less expensive than some specialty Kent-Moore tool. Although I have the Kent-Moore flywheel tool for holding the crankshaft steady while you torque the harmonic balancer bolt on my LS1 in my C5.
I haven't worked on a small block Chevy in about 30 years and I don't recall exactly where the drain plugs are.I wont pull the engine unless I have to.Could you give me a little more detail on exactly where they are?
Thanks for all the responses,I do plan on cleaning the entire cooling system really good.I do need help locating the plugs on the block.Thanks for the pic John Z, I will make something similar. I guess you need gaskets on both sides of the engine support for water pump.I also see that there is a 1 inch gap on top of radiator to shroud,seems like a lot of air could bypass radiator that way?One other question can the oil pan be pulled and the gaskets changed with engine still in place??
There is one drain plug on each side of the engine block located just above the oil pan mounting flange. They're accessable from below. Most I've seen are a threaded steel plug with a square head but I have seen hex head bolts used also. I replaced mine with brass many years ago so they come out easy. Rich
Inspect the mounting points and bolts carefully on removal. It is a stress point on these cars. There are some who have even made a reinforcing plate for those areas. Can't recall specifically but Tom Parsons might be one DZAuto on here...
Make sure that you use the correct type of sealer on the gaskets. The wrong type will allow the water pump and motor mount to shift from the torque of the engine and leak.
I think that silicon is the type that should NOT be used, someone will correct me if I am wrong.
