rough riding c2, help
Old Apr 9, 2015 | 03:11 PM
65 vette dude's Avatar
65 vette dude
If you want a smooth comfortable ride, just put on the cheapest Monroe, or Gabriel passenger car shocks that fit your car. They have a softer valving. I had a set of KYB GR2's on my car and hated them. They rode very stiff, and I took them off and put a set of AC Delco shocks on...... they are much better, but still a little on the stiff side. Can you tell what shocks you have now?
Old Apr 9, 2015 | 03:28 PM
old68's Avatar
old68
Default monroe in front
Monroe in front & no name yellow in back
Old Apr 9, 2015 | 03:50 PM
Vet65te's Avatar
Vet65te
The rear leaf spring should have a slight arch to it, it shouldn't be flat. If you're not that familiar with Corvette suspensions, maybe another local Forum Member who is familiar could stop by to give it a look over.
One other thing to ask, since you said the Cokers were new, have you checked the air pressure lately? Most shops overinflate new tires to make sure the bead seats well but they might have forgotten to drop the pressure afterwards. Easy thing to double check.
Mike T - Prescott AZ
Old Apr 9, 2015 | 04:01 PM
C2Racer's Avatar
C2Racer
Okay, that looks like a 7 leaf which should have a 15/16" front sway bar for the F41. Check that first to know what you have. As mentioned this set up will be stiffer and will require at least rear shocks with more rebound control as they came from the factory.
I drive race cars and Porsche's daily so I like stiff suspensions but ones that are under control. I have a 7 leaf on the rear of my 64 street car with Koni adjustable's to control rebound and 460# front springs with Bilstien HD's. Sounds screwed up I know but a lot of experimenting and I cut the front springs with longer rear bolts to lower the car in the rear. What I ended up with is a solid feeling suspension with no bounce. The bounce was driving me crazy. It handles RR crossings and normal stuff well although wash board stuff I have not encountered but this is a big improvement from worn out KYB's and an old 9 leaf spring the car came with. The entire car feels more solid and really not like a 64 anymore. Good luck with yours but this should give you something to think about. You went from smooth to stiff in your posts so I'm not sure what your goal is?
Steve
Old Apr 9, 2015 | 04:02 PM
old68's Avatar
old68
Default maybe it is what it is
she handles great on smooth roads, so maybe it is what it is, I am just trying to get her sorted out, so i don't mind spending some $ on her as she is such a pretty thing, the same age as my wife and almost as pretty,
Old Apr 9, 2015 | 04:19 PM
old68's Avatar
old68
Default double checked
Steve
thanks Steve, I double checked , its sway bar in front, 7 leaf in back, what do I do now???
Old Apr 9, 2015 | 04:28 PM
old68's Avatar
old68
Default I think the goal is
Steve
I think the goal is a softer ride, so it doesn't chatter so much on the country roads, so many pretty roads here, so we like to just cruise slow and take it all in,
Old Apr 9, 2015 | 04:51 PM
JohnZ's Avatar
JohnZ
What's the sway bar diameter? Should be 3/4".
You have a rock-hard F41 rear spring - get an Eaton-Detroit 9-leaf.
Put a full set of AC-Delco, Gabriel, or Monroe standard shocks on it.
Don't know what front springs you have, but you don't want any spring that has "460" in its description.
Old Apr 9, 2015 | 04:53 PM
C2Racer's Avatar
C2Racer
The 7 leaf is not built for that. I would recommend like others have a 9 leaf rear and Bilstein HD shocks that offer a little more control than the cheaper ones. But bounce is going to be more prominent if that doesn't bother you. Could drag the muffler clamps on big longer bumps too with this set up from my experience.
Steve
Old Apr 9, 2015 | 05:07 PM
old68's Avatar
old68
Default drag clamps?
Steve
no mufflers , sidepipes, is that ok?
Old Apr 9, 2015 | 05:09 PM
old68's Avatar
old68
so is consensus 9 leaf + new shocks?? I bounced the car today & the front moves nice, bit the rear barely moves at all,
Old Apr 9, 2015 | 05:10 PM
old68's Avatar
old68
Default oops forgot to ask
will that affect my ride height?? its always a bummer when you get the car off the lift and its sits weird
Old Apr 9, 2015 | 05:15 PM
  #33
DansYellow66's Avatar
DansYellow66
Without knowing your past experiences with older cars - if you haven't owned a convertible sports car from back in the 50s and 60s, they were not exactly known for their rock-solid design and construction. Some body movement, cowl shake and chatter is pretty much par for the course with these convertibles over rougher roads.
My BB coupe with standard suspension and older gas shocks actually rides very nice - just a bit bouncy in the back. But coupes are a little stiffer and with sidepipes and a bit of hearing loss, rattles are not an issue at all.
I can't see your coil springs in that one picture clearly. F41 front coils are spaced more widely apart and the wire diameter is greater. Standard coils have more coils and are more closely spaced - nearly touching on some well worn springs. I would also count the leafs in the rear spring. My car had a 10th spring leaf inserted in it when I first bought it to elevate the car - also made it ride harder. A 9 leaf spring should not be harsh riding unless maybe all the bushings and shocks are completely shot.
Old Apr 9, 2015 | 05:16 PM
  #34
C2Racer's Avatar
C2Racer
It can but nothing that can't be adjusted back to where you want it. The rear is easy to adjust height on, two bolts. Side pipes no problem, should have remembered that. Good luck.
Steve
Old Apr 9, 2015 | 05:24 PM
  #35
old68's Avatar
old68
Default wide springs
its got the wide spaced front springs, I don't mind an older ride, I am coming from a 67 camaro convertible and that seems quite a bit smoother, I don't mind some bounce, its just the chatter at 15-20-30 mph is really harsh, must be tough on the body too
Old Apr 9, 2015 | 05:31 PM
  #36
65 vette dude
Bilstein HD are yellow shocks, with some light blue markings on them. They are a high end shock, which are excellent handling, but tend to be a little on the stiff side. If your Monroe's are blue, I believe that's their economy shock.
Old Apr 9, 2015 | 10:08 PM
  #37
Gary's '66's Avatar
Gary's '66
This chatter you keep referring to could be something as simple as a loose shock or something else that just needs to be tightened or adjusted. I'd spend a little time trying to locate it before spending a bunch of $ replacing parts. Just my .02
Gary
To rough riding c2, help
Old Apr 9, 2015 | 10:18 PM
  #38
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
What tire pressurize are you running? If you are up at max inflation pressure as listed on the sidewall, usually 40-44 lbs, it is way too much and it will make the car ride hard.
Tom
Old Apr 9, 2015 | 11:26 PM
  #39
Vet65te's Avatar
Vet65te
Tom
Tom - I asked the OP that same question back in post #23 but no reply yet.
Old Apr 10, 2015 | 07:18 AM
  #40
MikeM's Avatar
MikeM
How many times do you have to say "7 leaf spring"?
