1965 Brake Lights Problem
Old Apr 11, 2015 | 07:14 AM
Csbsteveb's Avatar
Csbsteveb
7th Gear
Default 1965 Brake Lights Problem
I have a 1965 - the brake lights on one side do not work. Turn signals, and headlights all work on both sides. Brake lights work on the other side just fine. Any Thoughts?
Old Apr 11, 2015 | 08:00 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Check the plug from the rear body harnes that plugs into the dash harnes. Make sure you got continuity between the two plugs on all wires. If that's good you might have bad bulbs
Old Apr 11, 2015 | 08:14 AM
6D2148's Avatar
6D2148
turn signal switch
Old Apr 11, 2015 | 08:47 AM
65GGvert's Avatar
65GGvert
The only electrical difference in the turn signal and the brake light on one side is the contact in the turn signal switch. When you turn on the turn signal to one side, it interrupts the brake light voltage and inserts the flasher voltage. It uses the same wire, same bulb, same filament, same ground for both the brake and the turn signal. So, the contact inside your turn signal is loose or corroded that goes to that side. Try holding the brake and wiggling the turn signal switch with the KEY OFF. If that brake light flashes or comes on while you're wiggling, you'll know for sure, but it could still be bad and not do that. Here's a picture of what those contacts look like. The cam from the signal switch stalk goes between the two curved prongs shown in the center. That's where your contact will be not making.
Old Apr 11, 2015 | 12:20 PM
Csbsteveb's Avatar
Csbsteveb
7th Gear
Default 1965 Brake Light Problem.
Thanks. I'll try it.
Old Apr 11, 2015 | 12:39 PM
DZVette's Avatar
DZVette
Attachment 47877562
Nice photo Jack.
I have combined your info with some from an earlier thread in which "buns" (Tim Welsh) posted a photo of a faulty repro switch with internal contact issues. A PDF file is attached for those who might want to add it to their reference files.
So far (12+ years), I've been lucky with the repro switch I put in.
Dave Z
Old Apr 12, 2015 | 11:20 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Originally Posted by 6D2148
turn signal switch
This ^^^
Tom
Old Apr 12, 2015 | 11:23 AM
66jack's Avatar
66jack
Brake Filament is out on BULB...
Old Apr 12, 2015 | 01:02 PM
65GGvert's Avatar
65GGvert
The turn signal and brake use the same filament. His turn signal is fine. See post 4.
Old Apr 13, 2015 | 07:51 AM
Csbsteveb's Avatar
Csbsteveb
7th Gear
Attachment 47877562
Ordering the parts today. You are correct....the bulbs are fine. Hop e to fix it this week. Thanks for your help!
Old Apr 13, 2015 | 08:05 AM
65specialk's Avatar
65specialk
Default Turn switch
[Q[B][/B]UOTE=Csbsteveb;1589404074]Ordering the parts today. You are correct....the bulbs are fine. Hop e to fix it this week. Thanks for your help![/QUOTE]
Who sells a good or the best switch??? Dave 65 Coupe
Old Apr 13, 2015 | 03:57 PM
Csbsteveb's Avatar
Csbsteveb
7th Gear
Who sells a good or the best switch??? Dave 65 Coupe[/QUOTE]
try Keen Parts out of Ohio
Old Apr 13, 2015 | 04:00 PM
JohnZ's Avatar
JohnZ
try Keen Parts out of Ohio[/QUOTE]
Or NAPA.
To 1965 Brake Lights Problem
