Comp thumper cams
Old Apr 26, 2015 | 09:19 AM
Freds65's Avatar
Freds65
Default Comp thumper cams
I have 65 with a 327 Was thinking about putting a thumper cam in. Does any one have any experience with these or recommend another to get that Hot Rod & Yesteryears sound
Old Apr 26, 2015 | 09:41 AM
65tripleblack's Avatar
65tripleblack
Thunpr cams are designed to sound mean, but they don't perform worth a shlt. They have way too much overlap.
Old Apr 26, 2015 | 10:25 AM
Scott Marzahl's Avatar
Scott Marzahl
You don't provide any details about your motor and or how your car is currently set up, and I agree with the above, pos cam that just makes noise.
Old Apr 26, 2015 | 06:29 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
The thumper cam is a desperate attempt at revenue creation. Sadly some embrace it. Makes me wonder where the car hobby is headed. Ron B.
Old Apr 26, 2015 | 06:45 PM
MikeM's Avatar
MikeM
...... or recommend another to get that Hot Rod & Yesteryears sound
I don't think they read what you wanted?
Old Apr 26, 2015 | 11:13 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You need to determine what you need. The Thumpr's aren't necessarily bad....just not perfect for everything. They've got an aggressive intake lobe.. and a longer duration exhaust with a tight LSA. Yep..you get overlap...but depending on the size of the cam...the heads and cubes...they can work OK.
I've found that the Crower #350 circle track cam works very well in street 327's and even larger engines with double hump heads. It's got a tight LSA..but idles clean..will rev to the moon...sounds wicked and doesn't hurt parts.
JIM
Old Apr 27, 2015 | 06:32 PM
GTOguy's Avatar
GTOguy
Too much information to get into real detail, but in summary: thumper type cams get the valves open sooner and hold them open longer. If you already have high compression, this can lead to detonation at various engine speeds. With the valves being open longer, engine vacuum drops. This can pull carburetor power valves open too early, and can cause lack of power brakes if you have them. The 'cool' sound is the result of an engine with poor idle qualities: you will have low power on the bottom end, and it will sting your eyes with the now very rich idle mixture due to the valve opening characteristics. With a bigger cam, you need stiffer rear end gears to get the engine up in the power band sooner. This results in bad highway manners. I have a big 'thumper' cam in my 4 speed tripower '65 GTO. It's been in there since 1981, when I was a 20 year old kid. Yes, it runs like a scalded cat, but it idles terribly and needs race gas to run. Doing it over, I would have gone with a stock camshaft. So, my advice, if you drive the car much on the street, would be to forego the 'thumper' cam.
Old Apr 27, 2015 | 07:03 PM
DansYellow66's Avatar
DansYellow66
It's difficult to tell if you are talking specifically about Competition Cams Series Thumper Cams or just old school race cams from the 60s and 70s.
http://www.compcams.com/thumpr/
There may not be a lot of difference. For what it's worth I'm still running one of those old race cams from Cam Dynamics.
Old Apr 28, 2015 | 09:02 AM
65tripleblack
I just thought of something. You can install a better cam that matches your drivetrain (or leave things as they are) and buy yourself a boom box. Play the soundtrack from the car chase scene in Bullitt while you're driving.
MikeM: As you well know, the OP gave no information for anyone to recommend "another". If the OP simply wants an engine that sounds mean, then my suggestion, here, should be sufficient. I'm surprised you didn't chime in with your super duper 151 cam, or your handy dandy 097 cam.
Old Apr 28, 2015 | 09:57 AM
MikeM's Avatar
MikeM
In post #3, you say you have a 400 hp 327. I see you are also searching for an intake manifold and another carburetor (bigger?).
https://www.corvetteforum.com/forums...need-info.html
If you really have 400 hp, the exhaust certainly won't sound like a 1953 straight 8 Buick. So, what's up with the engine you have in the car now? Or was the 400 hp a typo?
Old Apr 29, 2015 | 10:25 AM
GTOguy's Avatar
GTOguy
Dan, I was refering to generic old school high performance cams. I looked in the Summit catalog and did indeed find the "THUMPR" cams by Comp Cams. 'intake and exhaust tailored to maximize the rough idle sound.." Kind of sounds to me like sticking cards in the spokes of your bicycle.
Old Apr 29, 2015 | 02:10 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I have wondered that since the popularity of cars that are entered in competitions to see how high they can bounce the front end off the ground using hydraulics, and seeing cars that look suspiciously like 1880 Conestoga wagons regarding wheels.
Old Apr 29, 2015 | 03:41 PM
MikeM's Avatar
MikeM
Looks like Freddy Boy posed his question then dropped off the radar. He hasn't been back since he posted.
Old Apr 30, 2015 | 06:41 PM
JohnZ's Avatar
JohnZ
Always wondered why some people's only criteria for a performance cam is what it sounds like at idle; must be the result of cam grinders marketing their product based on what they sound like at idle.
Old May 1, 2015 | 02:36 AM
TCracingCA's Avatar
TCracingCA
Default I think i am single handedly going to hurt Comp Cam sells!
Thumper!
To Comp thumper cams
