Distributor Replacement
The link below will take you to a "Timing 101" article that explains ignition timing and advance systems:
http://www.camaros.org/pdf/timing101.pdf
Now I'm wondering about trying to repair the distributor. Lars seems to get a lot of favorable endorsements for setting one up. How do I get in touch with Lars?
Maybe I should just go with a new Pertronix distributor? This car is a driver, not a NCRS car.
Thanks again for your valued input.
Also don't see how a car can be tuned to perfection, if the unit is traveling back and forth UPS!
Any thoughts on replacing the points with an electronic module, or replacing the entire distributor? The current distributor has had the vacuum advance can removed.
TIA, Gene
Therefore I don't think converting a ""dual point unit"" would be a good idea!
On a lower HP car, where you are wanting the broadest range in rpm operation, it would be good to return to vacuum advance, because the non vacuum units are usually set up to hit in a certain rpm range, all in and suddenly like in Poker! Tuning your advance weights can improve that, but that is the area of true experts with distributor machines! No one with stock components or pertronix type setups with vacuum advance should actually need an expert! If you continued to run dual point and no vacuum, then a guy like a Lars would be worth the investment!
Last edited by TCracingCA; May 19, 2015 at 03:15 AM. Reason: ADDED ((by increased dwell))
Yes you are very perceptive also!
So i would recommend Lars, DZAuto, and Plasticman for the special stuff, but naturally these individuals are also way more highly qualified for this type of basic and really simple routine work also!
Yes single spark of longer length, generated by a dual point firing! Do you feel better now! But some and alot can classify the firing of a point set as a spark. it is a version of jumping from contact to contact that differs from other spark transmission where a spark plug gap is jumped! and location where current is passed, can be essentially classified as a spark! PS when the points get burned, a spark, a sizzle, or conduction of electrical or whatever you want to call it, usually causes that! Therefore the gap is important to shut that conduction down.
How far would you like to go with this?
http://randysrepairshop.net/basic-ig...-it-works.html
For the newbs, this is a pretty good description how points work.
Since we were turned to travel down that rode for the exact technical, this was a very wise post (MikeM)!!!!!
I was just bothered that all of the experts came on and didn't think to address the OP's dual point unit! Started down a road of pertronix recommendations and such! Wow! Scary!
And PS-- if this """dual point""" would have actually ended up in the hands of Lars, I know he would have straightened it all out prior to it going down the wrong path!
TIA, Gene
Exactly what is the "upgrade on the distributor" that you speak of here (bolded above)? Did you add dual points? Did the dizzy come with dual points already installed?
If you DO have dual points, I don't think that you can install a vacuum advance diaphragm. Somebody correct me if I'm wrong, but aren't dual points and vacuum advance mutually exclusive?
From what you've posted, I don't believe that you need a new dizzy. The ones with tach drives are pretty costly too!
Yogi
I know you said NOT an show car, but do you want to maintain a fairly stock look, with the distributor and plug wiring under the metal shielding? That influences your options.
Unless you have a really high-revving, non-stock engine, why are you worried about point bounce? And if you are, my (very limited
) understanding is that point bounce would be addressed by heavy-duty, racing-type points that are sprung maybe twice as stiffly as stock points, (Probably wear the out the rubbing block faster?) If your engine is pretty much stock, and the factory didn't build it with dual points, I don't think dual points are going to do anything for you. I think, as others are saying, what you need is a stock Delco distributor with the proper vacuum advance can, set up by someone who is knowledgeable and experienced with such things. Either with stock-type single points or any of the various breakerless conversions, including Pertronix. Probably best to get it back to stock and work with points first. When you have it working well, you may then lose interest in the breakerless conversion. Or not.Just my two percent of a dollar.
Steve
Steve
Steve
