Diff oil changes
Old May 17, 2015 | 12:50 AM
00fxd's Avatar
00fxd
Default Diff oil changes
Does anyone have any suggestions why I have to change my diff oil every 2 years? I put about 5 - 10 thousand miles on a year and every second year it seems, that growl comes back so I change the oil and add 1 1/2 or 2 GM additives.
Old May 17, 2015 | 11:45 AM
GTOguy's Avatar
GTOguy
Not normal. You probably have a mechanical issue with gear pattern or bearing wear...was your rear rebuilt or is it original, etc. Gear lube lasts for years and years and many miles. It really doesn't wear out. The reason to change it is usually contamination from moisture or hard parts failure, or because it got burnt/overheated (again, from parts/component failure). Hopefully others will chime in.
Old May 17, 2015 | 12:02 PM
GEM '62's Avatar
GEM '62
Default another differential question
If I switch between two differential a couple times in a year, can I pump out the lube and reuse it or do I need to put new lube in each time I change?
Old May 17, 2015 | 12:22 PM
00fxd's Avatar
00fxd
The diff was an exchange unit a few years ago from Duntov Motor Company in Texas. I ordered the best one available at the time with the better yokes etc.
Old May 17, 2015 | 07:45 PM
00fxd's Avatar
00fxd
I should also mention that my side yokes seem to be working they're way inwards, there seems to be a lot of in out play, but kinda always has been with this unit. Probably only 25k miles on it. I should get this resolved, lots of touring planned for this summer. Does anyone have any thoughts?
Old May 17, 2015 | 08:54 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You should call them and ask them why the diff they built doesn't work properly.
Old May 17, 2015 | 11:42 PM
00fxd's Avatar
00fxd
Thanks Jim, yeh thats next. After the weekend. It's been a few years, I'm sure any warranty period has expired.
Old May 18, 2015 | 04:07 PM
427435's Avatar
427435
Does the "growl" occur when driving straight or just when turning??
Old May 18, 2015 | 05:15 PM
00fxd's Avatar
00fxd
The growl occurs when turning, even slightly. I'm wondering if the clutches are wearing prematurely allowing the stub yokes to move inward, is that a possibility?
Old May 18, 2015 | 05:45 PM
csysman's Avatar
csysman
sorry dont mean to hyjack your thread - hoping to learn something about what needs to be done to repair I had the same noise on left turns only on my 67 - but it only happened 2 x's I am waiting for it to appear again--- its been 3 weeks still no growel -
csysman
Old May 19, 2015 | 06:53 PM
JohnZ's Avatar
JohnZ
The stub axles are ALWAYS forced inward against the cross pin, by design; the Corvette rear suspension geometry maintains inward pressure on both yokes at all times (unless the suspension is hanging free in full rebound, and that can only occur while driving the car if you "get air"). That's why the face of the inboard ends of the yokes are case-hardened - when that layer is gone, wear proceeds rapidly to the ring groove, and you lose the snap ring clips, then the groove too.
Old May 19, 2015 | 09:45 PM
00fxd's Avatar
00fxd
Thanks John. I understand that the wheel drive-shafts also act as a stressed member of the suspension. My biggest concern I think, besides the repeated need to change the diff oil, is that there seems to be way too much in/out movement on the side yokes with suspension hanging and getting worse. I see on another thread that tbarb concurs that when the clutches wear the yokes are allowed move further inwards. Could this be the situation? I do have infinite adjustments on the camber strut rods, after-market Spherical rod end assemblies, so I won't be able to tell by running out of adjustability..
Old May 20, 2015 | 11:14 AM
Jackfit's Avatar
Jackfit
Hi, have a look at my post
Go Back Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Tell me it is a good thing to have gray metal fake in your rear end oil
It may jelp
Old May 20, 2015 | 12:39 PM
00fxd's Avatar
00fxd
Hi Jack, I did follow that thread. I saved the oils from the last change, there was not any sign of any flake at the time. I will be looking in the oil in this change for 'evidence'.
To Diff oil changes
