What are you guys using for a distributor/ignition that may actually fit under the ignition shielding (just for looks) that would have a tach drive?
The '62 I picked up recently has a non vacuum advance single point distributor in it with a weak pair of springs on the mechanical advance below the rotor. It has a tach drive. I know it isn't set up right and it's not correct for the car, but it's a NOM so it doesn't matter. Eventually I'll swap an LS3 into it but for now I just want a driver/cruiser. Stock distributors on Ebay have dreamer pricing.
Thanks.
I'm in the same boat with my '61. It has a NOM and a 1959 FI distributor that works just fine, but is not 'correct' for my car. My plan is to sell it and install a much cheaper '63-'73 tach drive distributor with a vacuum advance, for better drivability/economy. And keep it points ignition, while I'm at it, as I am a fan of the old-school ignition points in all my old cars. You can do a search and get a '63-'73 style distributor already converted to HEI, or do the conversion yourself, if you want to. Not hard, and it'll fit under the hood and under the shielding.
I'm not sure the HEI will fit under the shielding but then I haven't tried it.
I thought there were some issues using a later (C2) dizzy on a C1 but don't remember the details....I'd do some research on that... Maybe it had to do with needing a right angle tach drive adapter or tach accuracy....I'm fuzzy on the details.
The petronix type HEI fits under the same cap and rotor, on the same breaker plate. Simply replaces the points. So yes, it will fit under the shield. This is NOT the huge, ugly, coil-in-cap HEI used from '75 on up. As for the angle of the cable, that may or may not be an issue, depending on how the dizzy is clocked. With my FI dizzy, with the cable and the oiling tube, I only have about a 15 degree arc of adjustability. Will post on my thread when I get it running for the second time, shortly!
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
On a 340 intake, you can move it what seems like an inch before either hitting the intake runner or the coil bracket.
PS- In before comment of "Pertronix- Unilite- all that whiz bang stuff is junk. Stick with good ole points.
If a MSD 8572 tach drive distributor, (which will fit under your shielding) is cheaper than a Delco-GM tach drive with vac advance, then use it. If not, then sell yours to TI Specialties and swap it for a rebuilt unit for a 1962 Corvette with vacuum advance. Have Dave install a M & H trigger instead of the points.
The 8572 likely comes with an adjustable vacuum advance diaphragm which will have to be adjusted to your engine's idle vacuum level in order to work properly. You also have to find a suitable manifold vacuum (NOT PORTED) tap which will feed the advance canister. Vacuum advance should begin to deploy when manifold vacuum drops to NOT LESS THAN 1.5 IN-HG BELOW median idle vacuum level if you have a cam installed with high overlap. With a cam of streetable overlap, then, 2 in-hg is preferable.
