Restoration question
Old Jun 16, 2015 | 08:39 AM
Mikesfreetime's Avatar
Mikesfreetime
Default Restoration question
First off I'm 75% through my 69 BB restoration but have been thinking about my 67. It is an all original driver I have owned for 10 years. It is a 327/350 4 speed AC (although removed by previous) , headrest, side pipe car. It needs the entire wiring harness replaced which I purchased awhile back. The motor and tranny has been gone through. It needs all the brakes and bushings replaced.
My question is what items should I look at replacing without going total frame off? I have a Ducati I came into and some trading power to get the work on the 67 in trade. I would rather go at him with my full list and work backwards.
Old Jun 16, 2015 | 09:27 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Make it safe. For 67 you can replace all the brake lines without removing the body. I would do that I would also rebuild the front and rear suspension with all new rubber bushings.
Old Jun 16, 2015 | 09:30 AM
67vetteal's Avatar
67vetteal
Body Mounts can be done with Body on Frame. New wiring Harness should be done as these cars tend to be Flammable. Al W.
Old Jun 16, 2015 | 09:45 AM
Mikesfreetime
Body mounts, wiring harness, brake lines, and suspension rebuild. Can the gas line be changed?
Old Jun 16, 2015 | 12:38 PM
Nowhere Man
You will have to get the body off the frame a good bit to get the fuel line replaced
Old Jun 16, 2015 | 01:35 PM
GTOguy's Avatar
GTOguy
Do whatever needs done mechanically, and drive it. That's where I'm at with my recently purchased, mostly original '61.
Old Aug 26, 2017 | 07:47 PM
reinkailua's Avatar
reinkailua
Default how do we view your photos
How do we access your photo?
Old Aug 27, 2017 | 04:57 PM
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
The thread is over 2 years old. The photos are gone.
Steve
To Restoration question
